Bluetooth ptid-8940nr
SOURCE: MY PTID 8940NR WILL NOT
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Antes que nada asegurese de que el dispositivo bluetooth este encendido.
Para poder sincronizarlo:
1. Enciende el PS3
2. En el men? Settings (Ajustes), seleccione Accessory Settings (Ajustes de accesorios) y presione X.
3. Presione X en el icono Register Bluetooth® Device (Registrar dispositivo Bluetooth®).
4. Despl?cese hacia abajo y presione X en el icono Register Headset/Microphone/Headphones (Registrar auriculares/micr?fono/auriculares).
5. En la siguiente pantalla, prepare el auricular para sincronizarlo con la PlayStation 3. Para hacerlo, presione el bot?n K1 durante 8 segundos.
6. Una vez que el indicador luminoso LED del auricular titile en azul y en fecha de comprarojo (lo que indica que el auricular ya se puede sincronizar), presione X en Start Scanning (Iniciar escaneo).
7. Una vez que se haya efectuado el escaneo, la PlayStation 3 reconocera todos los dispositivos Bluetooth que se encuentren dentro del ?rea de alcance del sistema.
8. Busque 8860 en la lista de dispositivos, seleccione el icono correspondiente y presione X para que se le solicite una clave.
9.Escriba 0000 (cuatro ceros) como clave y presione X en OK.
10.A continuaci?n, aparecer? el mensaje: Register completed (Registro finalizado).
