Bought the scanner, and it is suppose to be compatible with Mac computer. I followed instructions to install on Mac, but I can only go so far and then a message pops up and says this is not longer supported . Any suggestions?
SOURCE: Scanner won't communicate with my Mac
Uninstall the software with scanner unplug from your MAC. Install the software with the scanner disconnected, then connect it b4 the first use of the software.
SOURCE: won't recognize scanner when installed
First, make sure your computer has been updated to at least Windows XP Service Pack 1....Service Pack 2 is even better. You can check this by right-clicking on my computer and selecting Properties from the menu. If you're using Service Pack 1 or earlier...it would be a good idea to run through the Windows Update process a few times.
Try downloading a new Scan Wizard file from this page on the MicroTek web site. When you do the install, it should remove any previous drivers and clean things up.
If this doesn't help, try to find the Windows Scanner and Camera Wizard...usually located under Start>All Programs>Accessories. It may work even if the MicroTek software doesn't.
Good luck...and I hope this is helpful!
SOURCE: Re: CanoScan LIDE 30 on Mac OS X (Version 10.5.6)
I was able to install the CanoScan Toolbox by doing the following: MacIntosh HD --> Library --> CFMSupport --> Get Info. Under 'Sharing & Permissions', I added my name & changed 'Read only' to 'Read & Write' .
Problem now: I can't install the LIDE 30 Scanner Driver. I clicked on the downloaded driver & a box opened. I clicked on ScanGear CS Installer, but that didn't work. I then clicked on 'Into Plug-In' --> ScanGear CS 7.0X --> Choose Application --> CanoScan Toolbox 4.1 --> Plug-Ins, but couldn't continue as the 'Open' tab was greyed out. What should I try? Any suggestions would be appreciated.
SOURCE: is snapscan touch compatable with vista?
When you've got the driver, you have to follow a special procedure to get it work. Follow this link:
http://home.torensma.net/index.php?page.id=13&article.id=207
SOURCE: I've bought a new computer running Windows 7 and I
you might need to download this to allows your computer to communicate with the scanner
ScanGEAR CS
http://software.canon-europe.com/software/0027828.asp?model=
