My refrigerator door handle fell off because the one of the metal brackets inside broke. I tried to order a new one from the service department phone number listed on the inside of the fridge. I have tried 3x to explain what the bracket looks like and they keep sending me the wrong one (even though I have given them the model and serial numbers).
The bracket inside the handle has a hole that fits onto a bolt sticking out of the fridge door. Once the holes are aligned I slide the handle down and it locks it into place. Should be an easy fix...right?! I noticed several people explaining this exact door handle. Where can I find the bracket or part number???
Please HELP
The inside bracket is not a separate part you will need to order a new handle that already will come with that bracket
Possible the source of the trouble you are having is the bracket might not be available or available separately.
Most parts lists have an exploded drawing showing all the parts and these are an invaluable aid to obtaining the correct spare parts.
I suggest you ask the service department to fax or email a drawing to you.
SOURCE: Amana refrigerator will not chill
That model number does not come up for me.
Click on and enter model number
http://www.searspartsdirect.com/partsdirect/index.action
SOURCE: I want to remove my Amana Refrigerator handles
The handles are probably attached with screws from the back -- this will require removing some panel(s) to access them.
SOURCE: How do I tighten the refridgerator door handle on a AFD2535 french door refrigerator
Instructions for removing and installing door handles are on pages 5-6 of manual at:
http://shop.amana.com/assets/pdfs/literature/User%20Instructions%20-%20W10175445A.pdf
SOURCE: Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
SOURCE: amana SBDE520N
HELLO, MY NAME IS TZINAS JOHN FROM GREECE AND I HAVE A PROBLEM WITH THE WRITE DOOR OF MY FREEZE.
THE MODEL IS * SBDE520S W *
THE PROBLEM IS THAT IT GET IT ALL THE DOOR DOWN FROM THE DOWN SIDE OF THIS.
I HAVE FIND THAT THE PROBLEM IS TO A LITLE PLASTIC PEASE FROM THE DOWN SIDE OF THE DOOR.
PLEASE CAN HELP ME WHERE I CAN FIND THIS PART???
give me a call and i will do my best to locate....866-798-4375
