When I hook up the RCA cables from the Phono to the AUX inputs the volume has to be turned all the way up just to hear any sound.
PHONO requires a phono-equipped receiver, which the STR-DE598 appears to NOT be. AUX will not work because it requires Line Level inout. Traditional old-school turntables put out a very tiny drastically-altered signal which needs preamplification to raise it and flatten it out for use by downstream circuitry. THAT is the job of the PHONO section in a preamp or receiver. You need to find a phono preamp or an older receiver to run the TT through. You could slave it to the STR through its AUX then.
What is the output source, ie line out or headphones out, from what unit ie radio, tv ??
