SOURCE: problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
SOURCE: i need the pinout of the jazzy 1103 ultra battery
The Output voltage 24 - 29v ,Usually 27v. (And 4 Amps)
The Pin arrangement is Negative to the Left, Inhibit in the Middle, And Positive to the Right Assuming your looking into the plug itself from the front.
Always check with a Voltmeter first though because there are some chargers with the Opposite Pin Arrangement.
SOURCE: y mom's jazzy 1103 ultra will not operate .
Make sure motors are in gear. Unplug from wall then try to turn on.
