Please first check whether the Vista Service Pack 1 or 2 is installed in the Computer and what is the version of the BIOS installed in the Computer.To check the information about the Service Pack installed:
Click on Start, type
WINVER in the Search area and then press the Enter key.
Or
Please goto Start Menu, select 'All programs', select 'Accessories' to access 'Run' option and enter '
WINVER' and check whether Windows Vista SP1 or 2 is installed in the Computer.
To check the version of the BIOS installed in the Computer:
MSINFO32 in the Search area and then press the Enter key.
In the System Information window check the BIOS version.
If the installed BIOS version is not
R1121Q0 or higher then install the BIOS update in the Computer from this
Link.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR220E&upd_id=3618&os_id=28This is a known issue with a VGN-CR series Computer when Audio may not work properly after installing Microsoft Windows Vista Service Pack 1 (SP1).
Installing the BIOS update should resolve the issue.
If the issue still persists after installing the BIOS update then you may try installing the Audio Driver from this
Link.
NOTE: Please first go for the BIOS update as it is a well known issue with a VGN-CR series Computers.Good Luck!!!!!!!!!!!!!
