I have a Phillips dlp projection TV. The color went out so I bought a new color wheel. When I opened it up the color wheel was destroyed. None of the color glass was on it. I cleaned all the pieces and installed the same part number color wheel. Everything is back together and working however the color on the left side of the screen is fine but about 1/4 across to the right it starts bleeding off. All the way on the right side its color but extremely faded. Is something assembeled wrong or another part possibly damaged by the color wheel flying apart?
I'm sorry to hear that you're having this issue with your TV. It may be an inverter board, or something internal having to do with the backlighting of the unit. I would recommend having the unit inspected by a technician.
SOURCE: color & sharpness problem
Sounds like you need Coolant fluid change, this is the fluid under the Lenses. If you have not done this before I suggest that you get some one who is qualified. Because if the coolant leaks and get to the circuit board, there goes your tv. You need new fluid in the 3 CRT's. If you look down with the back off and looking in the lense, you would see contamination in the fluid, this needs to be taken out and cleaned and replaced with new fluid. The fluid can come from places like MCM electronics corp.
SOURCE: picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
SOURCE: I have a 56" DLP Samsung (HLR5668W) Right side goes solid black
The color wheels will never fix an issue like that. The only things that will cause that issue is a bad DMD board which is part of the light engine or the digital board which is not. Freak Squad need to replace the digital board.
SOURCE: Our DLP Samsung started making loud humming noises
Color Wheel and no you cannot clean it, you have to replace it, this wheel turns 9,000rpms per second and if not replaced and you keep playing set with it like that it can fall into tiny pieces causing Damage to light engine which then light engine cost $950.00
Call Encompass Parts for Color Wheel #part number
1-800-638-3328
SOURCE: Phillips Model # 60P8341A projection tv colors
look in the crts to see if coolent liquide is yellowest adn dirty like trash floting in it the crts cant display a clear picture if that the case you need to change the coolent in the crts. make sure the convergences is set good also. cloudy coolent makes tv lool out of focus. ig
the tv was fine till the color wheel fell apart. there was no color bleeding prior to that. do you think there could be light engine damage?
