Is there no "insert" key? Normally you tap th einsert key and it toggles between insert and over-write (or strike-over) mode. If there is a numeric keypad tape the "0" key on it provided the numeric pad is disabled. Same thing.
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed. LED A: Indicates that the Caps Lock (Capital lock) key is on when lit. LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
