SOURCE: will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
SOURCE: How do I make my printer stop printing a test page at power up?
Hello Guys
Check this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00473766&cc=us&lc=en&dlc=en&product=1103491&dlc=en&lang=en
enjoy
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
SOURCE: Printer prints partial page and then stops
We have had the same problem. I have found that if I close all windows not being used on the computer, then try to print the document again the entire document prints. This happens on an older computer we have that doesn't have alot of RAM.
SOURCE: Printer keeps saying Press Enter to align cartridges
Well you have landed at the right place.All you have to do is:
This should bypass the print alignment function and allow you to print.
If it still dosn't fix then :
Then follow the steps on this link :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&lang=en&cc=us&product=79499&dlc=en&docname=c00042820
Thanks.
Fame !
