SOURCE: auto sensing does not work. dryer continues to run
Inside the drum under the filter is 2 long skinny strips of metal mounted in plastic. Clean then sensors up with alcohol. They get goop on them from soap and fab softener. I have a manual here that feature auto sensing circuits and photos CLICK HERE FOR THE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: When I dry my clothes, the first cycle does not
If the dryer is heating You most likely have a venting issue. If your vent goes a long way or is flexible and has ess curves it could be plugged. remove and inspect the entire vent system to eliminate this as the cause.
