You don't say if its manual or auto? Looking at its age its possible the emission control valves/hoses may be blocked and it just needs a full service and these things checked by a trained person. Check the service periods and go from there. It may be that if all is correct then a person with a screwdriver is all it needs.
The idle speed on pretty much all vehicles newer then a 1988 are all controlled by the vehicles on board computer, and the sensors which supply the computer with its information. If you are having problems with an idle that is either to high or to low you might want to check your throttle positioning sensor. A vacuum leak may also cause a vehicle to have a high or low idle. I hope this helps you out.
The accelerator cable had slack in it a was right against the idle stop.
I adjusted so it was tight and was about the thickness of a sheet of paper off of the stop. Now it does not stall at idle when warm.
escudo 2.0 V6, the idle is ok and the rpm quite ok, but smoke is so heavy when start in the morning, it dosent run smooth. can you help me to, i already change the spark plug but same stoyr, any solution?
