Home Logo
E
Eric Sellinger Posted on Nov 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My duravit toilet was hung too low and I'm trying to find a solution that doesn't require opening the wall
mikadot
Level 3:
  • Master 2,113 Answers
  • Posted on Nov 29, 2013
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
466304
Points
5959
If you raise the toilet you will have to raise the plumbing so you have little choice.
5 Related Answers
stefano-61
Stefano Andreani
  • 69 Answers
  • Posted on Jan 05, 2009
SOURCE: How do i get the top off of my duravit toilet??
try to check if there is any screw on the side of pulling knob...try to pull it and chek around it...good luck!
best rgds Stefano
Anonymous
  • Posted on Apr 09, 2009
SOURCE: maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Anonymous
  • Posted on Nov 03, 2009
SOURCE: my duravit toilet keeps running
I too have had this problem. No matter how i change the settings ..sooner or later the toilet starts to flow continually getting worse and worse. I have had plummers and friends etc see if they can make it stop and it is no better. I am very disapointed with it and will never ever buy Duravit again. I tried contacting them for help and got nowhere. Bad design. Waste of money.. I should have stuck with the old ball-**** system at B&Q.
Anonymous
  • 119 Answers
  • Posted on Nov 15, 2009
SOURCE: How do I remove the toilet seat for duravit
You need an open end wrench or socket I believe 9/16 is the size
Anonymous
  • 3006 Answers
  • Posted on May 29, 2010
SOURCE: Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
How do you get the water supply hose, which is behind the toilet to connect with the water supply valve on the wall? Duravit says the back of the toilet is slightly curved, but I don't see how the water...
Are the install correct ?I can't believe an install time frame where the technician is actually on time! Work was done quickly and efficiently. Definitely one of the best install experience I've had. Thank You.
Heated Toilet Seat Installation
1helpful
The hinges of Duravit toilet cover seat 006331 are broken. Where can I get replacements?
I have not been able to find a "tribeca" on the Duravit website but on the site of one of their parts distributors I found the Duravit Toilet Seat DUR 006331000. Is this your model? Starck 3
On the Duravit website this product looks very similar but not the same number.
I was not able to find replacement hinges for this model sold separately. You might consider using their Find a Retailer feature to find an outlet close to you where you might make inquiries or order hinges and/or a new lid.
2helpful
My geberit in-wall toilet won't stop running, and there is no way to access any type of plumbing fixtures to fix. Please help me!
Shut off main water supply
shut off water value going to your wall mounted toilet.
look under your apartment or the room ajoining the wall unit.
look for hidden wall space above unit
2helpful
Running water in Geberit Starck Toilet
I hate to say it but you may need a pro on this one, if you want I can try to walk you threw it but let me know. [email protected]
Top Duravit Home Experts
Mike Cairns
Mike Cairns
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Duravit Home Expert? Answer questions, earn points and help others
