Coby 40 TFTV4028 LCD TV Logo
R
Ray Finkle Posted on Nov 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Coby 40 LCD TV has splash screen and sound, but no picture
When the TV is turned on it will show the splash screen (Coby's symbol or whatever) for about a second before going black. The screen is completely black. There's sound, the menus work, I managed to switch video source, but still no video or the menus. The standby light is on when the TV is off and glows brighter when turned on before ultimately turning off completely when the black screen comes. I have inklings of what's wrong, but I'd appreciate some outside input.
Eli Isakov
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 99 Answers
  • Posted on Nov 05, 2013
Eli Isakov
Expert
Level 2:
Cheetah:
Answers
99
Questions
0
Helped
29387
Points
211
Looks like you might have issues with your screen it self the lights and all internal issues. You might have to take into a repair shop to get it done, a fuse might have been blown up. If you have warranty try to take it in and get it fixed.
3 Related Answers
Back2life Electronics
  • 933 Answers
  • Posted on Apr 11, 2012
SOURCE: My Coby 40 inch HDTV wont turn on. The blue light
I had a 32" Coby that did the same thing, turned out to be a defective main board. The main board wasn't sending the 3.3v signal to wake up the power supply. In my case I sold the tv for parts because it wasn't cost effective to replace the main board. It sound like your main board
Anonymous
  • 14553 Answers
  • Posted on May 27, 2012
SOURCE: my coby tftv3227 tv won't turn on and has no sound plugged it in new power source and still nothing what to do?
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_27_2012_5_44_12_pm.jpg5_27_2012_5_44_31_pm.jpg
AlamBhai
  • Posted on Oct 01, 2013
SOURCE: My coby tftv3229 wont turn on and I've only had it
Coby TV only Flashing it's logo , and will not turn on, not working.
How to test my tv to find bad part to replace ?
Mr. Folk have you took a flashlight when picture goes off and shine in screen and press like menu button and look to see if you can see any letters or anything, if so you probably have a defective screen assy or backlight. This may help?
TV SYMBOL COMES ON TV GOES BLACK NO SOUND OR ANYTHING HOW TO REPAIR THIS
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the ...the the tv turns on but there is no picture or sound and I can't seem to fix it the .... +tbones11234 I have the same on myHisense 55" TV,what did you ... The problem is when i turned it on it shows on the screen the sony logo three times then its ...
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Click Here to BUY TV REPAIR P... ... I Have a Hisense Tv in My Screen Is Not Working Right The brightness is ... Hi my TV shows the picture for a moment and then goes .... here the sounds but you cant see nothing and a sanyo flat screene.
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
2answers
Can a tv inverter board cause tv to not display
inverter board may be used to power backlight for the lcd display. If it is similar to laptop lcd displays in functionality .
http://www.ehow.com/how_7501465_check-tv-inverter-board.html
My 19 inch Emerson tv screen has went blue an no picture isn't showing
Sounds like a bad connection to whatever you have it connected to (cable box, dvd player, etc). Check the connection and then replace cables.
Coby tv sound problems
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Hooking up a sony dav is 10 to my 40 inch coby lcd tv
Hi, unfortunately Coby is not manufactured any longer. I have a problem not the same as yours, but I can't use my headphone when using my Panasonic Blu-Ray player. Have to use the sony digital surround sound. nothing comes through the Coby...If you have an extended warranty, I would call and have it replaced with another 40 inch brand..They can't fix it.I'm calling to have mine replaced or repaired...sorry i couldn't be better at helping..
Where can I find the Coby LCD TV code for a universal remote
Coby uses Samsung parts in their TVs such as the screen itself and the control board. My suggestion would be to try Samsung remote codes. I did this with a Coby 40" LCD TV
No picture on coby tv
I'm not certain but it sounds like there is a loose video cable in there...if you are able to, take the tv apart, and literally push on all of the connectors and cables to make sure they are not loose. The main video cable may not seem to be loose, but once it is making contact again, it should clear that mess up. Just look for cables running to the main screen and pull them off and put them back. Then put the tv back together again and see if it worked...it usually does. why does this happen? Some blame it on dust, others blame it on quick manufacturing processes...whatever the case, the cables become slightly seperated from the controller board and that happens...it also happens to computer monitors too...Good luck and take your time. If there are a lot of screws and things either take pictures of where they all went or write it down. I like to make a diagram on a piece of paper and tape the screws on the diagram to show where they went.
1helpful
2answers
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Top Coby Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Mikey
Mikey
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
