SOURCE: cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
SOURCE: Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
SOURCE: How do I set the time on cuisinart coffee maker
Set the function knob to CLOCK
Press and hold the HR button for a few seconds if the clock display time is not flashing
Once display time is flashing:
Press and release the HR button a few times for it to advance - it will say "PM" on the display if it is set for PM
Press and release the MIN button to set the mins
SOURCE: Coffee overflows
I have a 1600 with the same problem. The problem is due to a poorly designed fit between the carafe and the drain plunger in the coffee basket. If you lift the carafe slightly, you will see the plunger has a long way to go. If you have the tendency to push the carafe fully to the back of the hotplate it makes this worse. OK, so now the fix, which worked for me. Find a small piece of plastic to glue to the top of the carafe lid. You just need a small dimple to push the coffee basket spring in further when you in sert the carafe on the hotplate. You should experiment a little first to see how thick it needs to be. Overall it's a poorly designed combination and someone needs a lesson in tolerancing.
SOURCE: the heater plate on cuisinart cbc-1600 coffee
The CBC-1600 comes with a thermal carafe. therefore, it doesn't rely on a heater plate to keep the coffee warm.
