SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
SOURCE: malfunction detected error code c 001a on minolta bizhub c350
Im thinking either it was moved improperly and the image units werent kept level, or maybe just sitting to long caused them to settle in. try (gently) removing the IU's and shaking them (keep them level) in order to unclog or redistribute the developer inside. (imagine sand in a horizontal tube. It has to be uniform all the way accoss the tube, and not settled into any one location)
SOURCE: Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Bizhub C350 Malfunction Code C-0510
I have this malfunction code, C-11A3, coming up on my Konica/Minolta Bizhub 350 copier/printer. Anyone know what it is? I don't use the techs, because they charge much I don't pay for the service anymore-seems like most things should be able to be fixed by the owner. I needed help for this code
