SOURCE: Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
SOURCE: swimming pool liner hole
If you go down to the bottom of the pool with a small block of wood (make sure the edges are rounded and sanded) and a hammer you can probally hammer the rock back into the ground. If you just pound it flush you can probally patch it just fine at that point.
SOURCE: How do i cut a hole in side of metal swimming
Use hole saw made for metal.
Then use bulkhead fitting to adapt hole to pipe thread
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
