SOURCE: 2006 TE250 Starter fuse blows when the turn signal is turned on
http://www.carlsalter.com/motorcycle-manuals.asp free pdf manual there. you definately have a short somewhere in your wiring, i am not familiar with huskies. possible behind the headlight
SOURCE: 30AMP FUSE KEEPS BLOWING WHEN I CONNECT THE BATTERY
i have had that happen when i accidentally hooked cables backwards to battery.red cable(pos) to post w/ + next to it & black cable(neg) to post w/ _ next to it is correct.
SOURCE: 08 650 executive, new battery but charging system doesn't charge
Your running off the battery until it dies. Check your chargng system. It should put out 13.0-14.5 volts. If not then the current will flow from what ever source has the most voltage. Thus, your dead battery. Try changing he voltage regulator and then check the stator next. Sometime stators can have burned section on them and reduce the voltage produced to the battery. Also check for really good connectin to the terminals. This can rob current and voltage by upt o 40%.
SOURCE: honda cb250 no start
check battery voltage,then battery voltage drop at starter relay [solenoid] if battery is good replace relay but make sure all connection are good
SOURCE: 2003 honda cb250 no start
starter solinoid has got wet,spray the electrics with wd40 to displace the water. if this does not remedy the fault then the starter solinoid will have to be replaced..hope this helps
