KitchenAid KUDC25CH Dishwasher Logo
T
Tom Maldonato Posted on Nov 05, 2013
KitchenAid Dishwasher KUDC25CH. I have a problem where the Child Lock LED blinks and cannot be reset. If found a few postings on the Internet and some lead to the electronics control board ($165) while others point to the machine front control panel ($130). I'm concerned that either purchase cannot be returned and am looking for any suggestions on how to test one vs. the other. One person on a website (http://www.partsimple.com/9744031r-wpl-r-12.html?gclid=CKaewr_ezLoCFUkV7AodnxAAgQ) noted that they had the same problem, purchased the electronic control board and found it showed the same error. He also noted that he was able to "...used a low voltage source and "rang" out each button, using a meter and observing the LEDs to assure all were working." In the end he concluded that "What may have happened, was the cover plastic may have aged enough to deform and kept one of several of the buttons depressed marginally...or at least enough to disable the unit." Any ideas on how to test one vs. the other? If I have to lay out $300 to ensure a fix, I may as well purchase a new dishwasher. the unit I'm trying to repair is 12 yrs old. Any suggestions appreciated.
3 Related Answers
Anonymous
  • 6 Answers
  • Posted on Oct 17, 2009
SOURCE: Dishwasher KUDC25CH; Control Panel is not working
WASH THE DISHES URESELF U LAZY ****!!! :)
Anonymous
  • 5081 Answers
  • Posted on Nov 08, 2010
SOURCE: KitchenAid dishwasher KUDS25SH - Can't operate because child lock
If holding the "Energy Saver/Dry" button does not solve the control board problem then most probably the control board would have failed and needs to be replaced .
To identify it we need technical expertise in handling the circuit boards and knowledge on usage of multimeter is must.
Anonymous
  • 1998 Answers
  • Posted on Jul 11, 2011
SOURCE: I have the KitchenAid undercounter
Did you try holding the energy save button for 10 seconds I thought that was how you were supposed to unlock the child lock on the unit. Also did you try unplugging the unit as well for 7 minutes this usually causes the control to reset in the unit. I await your reply to how you make out with these suggestions. If this does not work then one or more of the pads on the control panel is stuck and if this were the case then you would have to replace the control panel if you have any further questions message me back. Thanks Rick
How do I shut off the child proof lock on my kitchenaid superba dishwasher? There is a red light blinking and I have no idea how it came on as I did not push anything different than I usually do when I...
Hi
To reset the dishwasher control you have to press and hold the HEATED DRY button for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 16, 2011 • Dishwashers
The dishwasher will not work. It appears to have no power.
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
9helpful
2answers
The KitchenAid dishwasher "child lock " is on and we can not star
Hi
Thanks for using FixYa. To turn off the child lock press and hold the Energy saver Dry for 10-15 seconds. If this does not help the unfortunately you’ll have to replace the control panel.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
3helpful
My KitchenAid dishwasher (KUDS25SH) start and stop
MY KUDI25 CHWH1 has the exact same problem...I'd love to hear about a fix!
2helpful
3answers
2helpful
Is there a removable filter on the KitchenAid KUDC25CH
Again, check the routing of the drain hose. The drain hose should belooped up in the cabinet under the sink. If it is not the water may be backing up into the Dishwasher
Child Lock
press and hold the lock button for 3 to 5 seconds id this does not unlock it then you need to replace the touch panel
1helpful
Clean led keeps blinking.
salvy, look for the lock symbol, it should be on the heated dry pad. Press and hold it until the lock led turns off. Catriver..post back.
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
