I have a 4GB Memory Stick Pro stick -- I can see the photos on the camera, but when I plug it into the hub / card reader, it's not being recognized. I suspect there may be some memory encoding issues going on with this card, as I sometimes get the "ACCESS" message when doing things like rotating an image on the camera. I also was experiencing some issues as I got to the end of the available memory, where it took a long time for the photos (7mgpxl) to write to the card; workaround was to turn the camera off and on, but I did lose some images now and then.
So: is there a way to directly connect my camera to download the images? or is there a workaround for getting the card reader to recognize the card? I was thinking of trying to delete some of the images, maybe take another photo, and see if that doesn't fix things.
TIA
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
