Question about Leviton 8599 GFCI Receptacle
Gfci trips with just a 40 watt light plugged in. Freezer was only appliance on circuit until this proble started 2 days ago. Replaced main gfci outlet and other receptacles on circuit
5 Suggested Answers
SOURCE:
rtpflh
  • 546 Answers
SOURCE: GFCI IS TRIPPING
how old is it ? GFI's internal parts wear out,can't be fixed.all three receptacles are being protected by the one w/GFI
Posted on Sep 21, 2009
agent91
  • 2100 Answers
SOURCE: I have an electrical circuit in my home that
They put the GFI in line at the front, all the other plugs run off it. One of the other plugs, has lost ground, has lost neutral, a simple plug in tester will tell you this, find the fault, or,, you have a fluorescent bulb plugged into it. The gfi's are very sensitive, they snap at the drop of the barometer.
Posted on Mar 14, 2010
Testimonial: "Wow. Your reply was almost instant. Thank you. I wish they would have suggested that at my local home improvement store before now!"
SOURCE: What does the orange light
Has indicator always been ON?
Or did it suddenly turn ON recently?
Usually small indicator lights show that device is working, and has power.
Then when GFCI trips, the light goes off.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 24, 2011
  • 3289 Answers
SOURCE: i hooked up a 20amp circuit breaker to a 15amp recp. then to a 20amp gfci but my outlet tester reads open nutral. what's wrong?
You've lost a neutral connection at: one of the terminals somewhere; inside the outlet; broken strap between the neutral pads on the standard outlet; or the tester is providing an erroneous indication.
Does it read OK on the BOTH receptacles of the first outlet? Check the terminals that provide output on the first outlet and the LINE terminals of the GFCI . Bad at the first outlet? Check the input on the first outlet. Bad? Check splices between outlet and service panel and neutral connection at neutral bus bar inside panel. OK? Check the input to the GFCI - make sure on LINE terminals and proper polarity is observed.
Double check the line and load terminal screws of the GFCI outlet. Make sure that the power coming into the GFCI is connected to the LINE terminals. Be sure to connect the HOT and NEUTRAL wires to the proper LINE terminals. Neutral conductor (white) connects to the silver colored screws and hot (black or red) connects to the gold colored LINE screws. If you are sending power out to supply additional loads that are to be GFCI protected, the rules above apply - but connect to the LOAD screws.
Posted on Jan 17, 2012
Refrigerator keeps tripping the GFCI outlet. We replaced the outlet. Still have problem. It first happened several months ago (just once), but has happened several times during last few days.
GFI circuit breakers are weak when used with refrigerators and other appliances that use amperage especially during defrost. Replace with a normal 20 amp receptacle
Appliance 911 Appliance 911 Sea Breeze
Aug 01, 2015 | Refrigerators
REFRIGERATOR KEEPS TRIPPING THE GFCI OUTLET
A GFCI detects shorts in an electrical system and isolates power to prevent that device from harming other components upstream. GFCI's do go bad so that possibility exists. However, I would recommend trying to plug in your refrigerator into another outlet in your kitchen that has a different GFCI plug. If it does not trip then the GFCI needs to be replaced. If you do not have another available GFCI outlet and you plug it into a regular outlet, your breaker for that service line MAY trip. Better off testing with another GFCI. If your second GFCI trips, then the problem is with your refrigerator...meaning you have a short in your refrigerator. If you think this is something you can troubleshoot...BE CAREFUL!!! Always unplug your refrigerator before going into the components of the refrigerator. One thing you can do is turn both the freezer and refrigerator temperatures OFF or to their lowest setting. Plug your refrigerator in and see if the GFCI trips. If it trips you have a major short...probably in the bottom of the refrigerator. If it does not trip, turn the freezer temperature on first and see if it will run without tripping the GFCI. If it runs, then turn the freezer temp OFF. Then repeat the process testing the refrigerator components. Ice makers have been known to generate shorts in the system as well. There are various ways to troubleshoot a fridge. If you do not have the required electrical troubleshooting skills then PLEASE call a service technician.
Nov 30, 2017 | Jenn-Air Refrigerators
My hot tub has been running perfectly until a few nights ago when the GFCI breaker tripped and now it wont reset
Either you have a ground fault or the GFCI is toasted. Turn off the power to the GFCI, open the box the GFCI is in and disconnect the output wires, close up the box, re-energize, and try to reset it again. This will tell you which problem you have.
Jun 04, 2012 | Cutler Hammer CH250 2 pole 50 amp
No, i have a 50 amp GFCI in my main panel and i am trying to feed a sub panel in my garage. i have power to everything until i plug anything in or turn on the lights.
GFCI's are really temperamental. They are this way for a reason. It seems like you have something that is tripping this. I would try using a regular 50 amp breaker, and then see what happens. You can also try process of elimination. Shut everything down, then bring power up - one item/circuit, appliance, etc. at a time. This will narrow down your problem. Also, if you have a refrig/freezer on this GFCI, this could be tripping it too. Any appliance, etc. that has a motor - usually leaks to ground just enough for the GFCI breaker to sense, and trip it. I hope some of these solution's will help you...Good Luck!
Sep 01, 2011 | Cutler Hammer 1 Pole 15 Amp Ground Fault
My side by side refrigerator started tripping the ground fault protector on the plug after being in the garage and working well. I have had the refrigerator for 10 years and this is the first problem I...
First question I would have is if the outlet is a dedicated line with nothing else on it. Also, does the GFCI in question have a high enough amperage rating for the refridgerator. Next, make sure the circuit breaker is not also a GFCI circuit breaker. You cannot have a redundant GFCI in the same circuit, one or the other. It can be very tricky to put an appliance like that on a GFCI circuit due to its compressor motor. Motors have a large amperage draw on them when they start so, if your fridge runs at around 10 amps, it can take three times as much to start (30 amps) which would trip a 20 amp GFCI.
Nov 29, 2010 | Frigidaire FRT15G4B Top Freezer...
GFCI circuit Breaker Trips
The neutral for that circuit must be connected under the neutral terminal connection set screw_on_ the GFCI breaker. The (usually coiled) white wire that is permanently connected to the GFCI breaker is then connected to the "neutral block in the panel."
Feb 14, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
Delfield freezer 6151-S keeps tripping GFCI
Try it in a normal plug. Freezers and refridgerators just pull too much to be used on a GFCI. The more a GFCI is used the eaiser it trips.
Aug 31, 2009 | Delfield Freezer 6151XLSR Stainless steel
Once in awhile, Circuit Breaker Trips
Your compressor start relay contacts may be getting loose or worn, resulting in a delayed start on the compressor.
If the start device includes a capacitor, it could be getting weak.
GFCI are not good receptacles for devices with high starting torque.
Apr 22, 2009 | Frigidaire Freezers
Kenmore 14CF upright freezer will die after a day or so
The defrost timer is faulty or you have a defrost circuit short, unplug remove back panel inside the freezer and check for a short in the heater and defrost thermostat.
Dec 30, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire freezer quits running
actionsnax please remove the freezer from the GFCI. What is happening on this old unit is that if the compressor shuts off then tries to come back on before the pressure in the system equalizes, the compressor can pull 12 amps. This is normally higher than the trip point of the GFCI. I had this happen years ago with a brand new Amana SXS refrig, in that case no one knew the unit was on a GFCI. The manufactures require that this units not be on a GFCI.
Hope this helps
Feb 01, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Leviton 8599 GFCI Receptacle Logo
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
boomanfoo
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
