Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
A
Anonymous Posted on Nov 04, 2013
AIR COMPESSOR MOTOR SLOWS DOWN - Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor
Liam Mcnulty
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 33 Answers
  • Posted on Oct 16, 2014
Liam Mcnulty
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
33
Questions
0
Helped
9157
Points
34
Capacitor problem not splitting phase sufficently
2answers
Failed capacitor on clarke SE 14 compessor
On electric motors with two capacitors, one is a start capacitor, the other is a run capacitor. Start capicitors have plastic cases and are rated from 200mf to 400mf and higher depending on the size of the motor. Run capacitors are in the 20mf to 40mf range and usually have metal cases. If you have an electric motor service center in the area they can recommend what size you should use for the size (HP) motor you have.
1helpful
I have an amana 90 home air conditioner w/ a amana prestige compressor. compessor runs but cooling fan not turning ,fan is not locked up and unit has power .of course w/fan not turning home is not...
Could be a couple of reasons for this:
1. Condensor fan motor bad.
2. Condensor fan motor loss of power.
3. Condensor fan motor capictor bad.
Unit has control for fan for low ambient operation and unit is low on freon telling fan its cold out side and dont run.
Hope this helps. wally
My compressor is working but my moter having loaded & burn i change another motor the same problem is happening. please guide me. thanks
The motor will run hot/overload if wrong size or too long cord is used. Also if pressure is set too high (most set at 125 ~ 135 at shut-off). In-tank checkvalve will also have effect on motor by loading the compressor at start-up. Easy test. Run compessor till you have over 100lbs in tank then unplug from power. At this point try to turn the motor /pump by hand, it should turn rather/very easily (this test is hard to do if the motor /pump is completely enclosed, you need to be able to turn the pump even if by truning the fan blade). If it does not turn easily let all the air pressure out of tank and then try to turn by hand. If it turns easily with tank empty try one more test. Run compessor till the pressure switch turns it off. Then unplug machine and turn compessor again by hand, should be easy. If not easy then unloader / checkvalve not working. The checkvalve could be leaking air back from the tank loading the pump. Replace parts as needed.
1helpful
MY COMPESSOR GAGE SHOWS 135 PSI AND 135 ON THE OUT PUT GAGE BUT I CAN,T INFLATE MY MOTORHOME TIRES TO THE REQUIRED 110#.DO I NEED A LARGER COMPRESSOR?I CAN,T FIND ANY LEAKS.
It is possible that the compressor psi as it is running drops below the tire psi creating a standoff. You must maintain air compressor psi over 110 to fill a tire to 110psi. Add air to your tire but stop when the compressor motor starts to run. When the motor stops then continue to add air until the compressor motor starts and again stop airing up the tire. Repeat as needed.
Air compessor wont start under load it is a airking 3 hp 3ph compessor and will not start under load.
was it running before? what ahpened to it? Is it on 3 phase service or a converter? Does it run with no air in it? Is there a trip for 2 or 3 circuits or just one? I would suspect th epower supply first, and then check the motor to see if it is ok. If it is a converter, they are only good for x amount or hours. Check it out.
2answers
My compessor wont start.
ALWAYS USE LARGE GAUGE CORDS FOR COMPRESSORS. LOOK FOR RESET BUTTONS OR THERMAL OVERLOAD BUTTON ON MOTOR. DID IT TRIP BREAKER OR GFI OUTLET?
Top Clarke Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
