Radio volume control on 2008 Subaru Tribeca does not ...
www.fixya.com/.../t25735073-radio_volume_control_2008_subaru_trib...
Jun 7, 2015 - Radio volume control on 2008 Subaru Tribeca does not work, but remote volume control on steering wheel works. ... does not... Replace the volume control(rheostat) inside the radio. .... Oct 09, 2014 ' 2007 Subaru B9 Tribeca.
SOURCE: radio lights
Try to adjust dash lights brighter. FOr some reason the radio blacks out even when the lights are dimmed a bit. Try turning the dash lights a bit brighter and see if you can see the radio. HAve a great day.
SOURCE: how to remove power steering pump on a 2007 subaru b9 tribeca
before start job suction out power steering fluid out of pump using large sirenge or siphon pump then.you need a table vise and two pieces of wood.okay to remove power steering pump. you need to disconnect the ground cable.remove air intake duct.remove the pulley cover.remove the drive belt.disconnect power steering pump switch connector.disconnect the pressure hose and the suction hose from the power steering pump.cover power steering hose and pipe keep getting trash dirt and debris.remove the installation bolt of the power steering pump bracket.place the oil pump bracket in a vise btween two pieces of wood keep from damaging bracket and remove the two bolts from the front side of the pump.remove bolt from rear side of the oil pump.disassemble the oil pump and the bracket by inserting flat tip screw driver.to install tighten oil pump to bracket bolts 12 ft lbs. tighten the bolt from the rear side of the oil pump to 27 ft lbs.tighten steering hose eye bolts to 30 ft lbs.replace fluid bleed air out power steering system.
