If I accidentally delete a Note from the Notes App. on my IPad, can I retrieve it? Is there someplace like the Trash Bin ( on my PC) that the deleted notes go to??
No, there's no trash bin per se. If you have a backup, you could restore it from that. If not, then maybe try recovery software like this. No idea if it works or not, though. http://www.wondershare.net/data-recovery/iphone-data-recovery.html?ici=index1
SOURCE: Can't delete emails from trash
Hello sir !
Empty Trash Can
In 1982, when Apple created the Apple Lisa user interface, they implemented what they called the Trash Can.
The trash can is essentially purgatory for files a user no longer
wants. Once sent to the trash, the user has the option of restoring the
file back to its original place, or annihilating it completely from the
computer’s hard drive. Unless there is a backup of a user’s system from
before the file was sent to the trash, there is essentially no way of
restoring that file once the trash has been emptied.
This metaphor was carried over to Windows 95
in the form of a Recycle Bin. Perched on the desktop of countless
millions of averages users was this bin which, when empty, looked
empty, and when it contained files, looked full.
There is safety in the Trash Can metaphor. I know that in order to
really delete a file from my system, either on Windows or on Mac OS X,
I really have to work at it. Yes, there are times when files are
accidentally deleted, but for the most part if I realize my mistake
before I empty my Trash, I know the file is safe.
SOURCE: how to empty trash in
In general, an iPad doesn't have a trash at all. Since you don't have access to the file system, files cannot be user-modified or deleted, so a trash is not necessary. Further, apps will generaly take care of their own cache and data usage, so user interventions doesn't generally occur. If you are talking about mail, try using the usual delete functions while navigating the Trash folder and you should permanently delete the message.
Hope this helps,
Alistair
SOURCE: Where is the trash bin on the IPad??
As mariolands said, there is no trash bin because Apple wants to make the device as simple as possible for users to use. Actually, if you think about it, a trash/recycle bin is not even necessary as the user does not need to worry about things like that.
If you were wondering how to remove apps, then you have to hold any app icon on the home screen for several seconds until they start wiggling. As they begin to wiggle, you should see a cross in the top corner of each app. To delete an app, just tap on the "x" and it should be deleted.
As for the mail, once you're in the mail app, just swipe right on the message you want to delete and an option to delete will appear on the right. Alternatively, you can tap Edit at the top right and select the message(s) you want to delete.
Hope this helps,
-virjog
SOURCE: I want Users Manual for Ipad recently purchased from Apple store
Go to http://support.apple.com/manuals/#ipad to download a user manual. Hope this helps.
SOURCE: how can i view the trash folder on ipad 1?
There is no trash folder on iPads, but you may be able to view the trash folder for the deleted email.
For instance if you use Gmail, Yahoo, or Hotmail, you could log into the web version of those services and check the trash bin and recover from there.
Hope that helps!
