Question about Tools & Hardware - Others
Where can I purchase 3/8 inch staples for my "old" bostitch T-5 manual staple gun ?
  • barry epp
    barry epp Nov 05, 2013
    definitely not at Canadian Tire / \mastercraft 3/8 won't fit
  • 122 Answers
Just about any hardware store. take the staple gun with you and ask a clerk or floor person.
Posted on Nov 05, 2013
SOURCE:
  • 2712 Answers
SOURCE: Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Posted on Aug 27, 2008
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
  • 384 Answers
SOURCE: stanley bostitch electric staple 02210 won't
You must have bought the Southern model. We work at a little slower pace here.
Posted on Sep 09, 2009
tbirdfan1
  • 3051 Answers
SOURCE: reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
Posted on Oct 03, 2009
  • 34 Answers
SOURCE: I have a very old Bostitch staple gun Model T5.
You should not need any tools to lift the guard/nose piece. The T5 nose piece cleary has engraved on it "Pull Up To Insert Staples". To remove old staples, use a pencil or similar rod to depress the hammer/striker above the staples while the nose is open.
Posted on Aug 07, 2010
Stanley TR 150 staples only going in half way. Why?
Hi Rene:
Don't know what materials you're working on, but you need to match the staple length with the thickness of the product being attached and the hardness of the material you're stapling into.
The intent is to attach one product to another. I'd go to a 1/4 inch staple for your application.
Jul 25, 2015 | Stanley ®Bostitch TR150 Staple Guns Tools
Can i use 3/4 inch brad nails in my stanley tre500 sharpshooter?
Morning Rhonda,
According to Stanley's own website, the TRE500 will only use either 1/2" or 5/8" brads.
Regards
Alex Bostitchtools co uk Bostitch Nailers Staplers Fasteners Coil Nails Staples
Mar 31, 2015 | Electric Stanley Tre500 Staple Gun /...
How do i load the staple gun?
1 Hold stapler upside down.
2. Release black plastic catch at rear and pull out.
3. Drop staples into bottom of gun, with open side up.
4. Push black plastic catch closed and latched.
wallyp
Oct 30, 2010 | Stanley Bostitch Pc4000oc2 Outward Clinch...
Where can I download a manual for Bostitch T5 Staple Gun
If you want to know how to load the staples, lift the wee flap at the end with the inscription " lift to insert staples".....
Jan 23, 2010 | Stanley Hand Tools
Bostitch nail gun number SB-21n1 is jammed and need manual to know how to unjam it or a solution online. Was using it in the staple mode and it jammed after about 5 staples. Was using bostitch staples.
Hello. Begin by disconnecting the air hose. That way you can not get hurt while removing the jam. Get a pair of needle nosed pliers and remove each of the jammed staples. They will pull out I assure you. Then Use a little WD-40 or compressor oil to lubricate the working mechanism at the firing head. IF you must loosen up the mechanism to remove all of the staple parts be sure to use the correct size allen wrench. I am providing link to a free manual for your gun in case you don't have one: http://bostitch.com/catalog_images/web_pdf/107674.pdf
Jan 12, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Staple gun
Oct 26, 2008 | Stanley Bostitch Pc2000 Staple Gun Tacker...
Tools & Hardware - Others Logo
287 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
