When requested to install told that not enough space on hard drive 39111 MB required and I have 32GB. Documentation on box indicates 4 GB of disk space required not 40 GB. Configuration data file on DVD has incorrect space requirement.
Re: When requested to install told that not enough space...
It may need additional temporary space. Now you say you have 32 GB and it requires 39 GB. That's 39 GB- 4 GB= 35 leaving a 3 GB play room. Too close for comfort. Eliminate those videos of the dog and cat playing, and you'll have tons of space.
<p>Disks are four kinds<br /><br />1- floppy disk small space size (1.44 M ) easy damage <br /><br />2- hard disk big space more fast (HD) from 1.5 GB to 1000 GB ( 1 tera ) easy use ,Difficult damage <br /><br />3- Compatible Disk cd start size from 200 MB to 8.7 GB, easy use easy move <br /><br />4- flash disk easy use easy move start size from 32 MB to 32GB (as i see) <br /><br />wish i'm helpful <br />
<p> <br />
<p> <br />
<p><br /><img src="nadereleraki_0.jpg" /><br />best regardes<br />
<span><a href="http://www.webanswers.com/share-question.cfm?q=what-is-the-difference-between-disk-and-cd-782c68">Share</a> ' <a href="http://www.webanswers.com/answer/1967137/technology-computers/computer-hardware/what-is-the-difference-between-disk-and-cd-782c68">Link</a> </span>
You need to free up some room on your computer. The game looks like it is requiring 39-40 gb of free disk space, and your pc only has 29gb of room. Try lookin at big hunks of media that is saved on your desktop. Normally video files are the largest. If you don't need them delete them. This will free up some space to install the software.
Maybe you need some hard disk space and Skype requires at least 256 MB of RAM and 18 MB of free hard-disk space for installation files. Try to delete some of your files that are not necessary especially images. To find out how much free disk space is on your computer:
Open your "My Computer" folder by clicking the icon on your desktop. If you do not have a shortcut on your desktop, open your "Start" menu and right-click on the "My Computer" icon.
2 Right-click on your hard drive icon. Generally, the hard drive is named the C: drive. Select the "Properties" option from the drop-down menu.
3 Read the pie chart and accompanying information to determine how much free disk space your hard drive has. Windows operating systems use blue to indicate how much disk space you are using and purple to depict how much free space is available.
If you have enough space, try to download SKYPE
If this would help you please don't forget to give rating.
Installing printmaster 2011 gold on PC. System Requirements: Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7* Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment: Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update) PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
FYI,
Minimum hardware requirements for Windows 98: 1. 486DX 66 megahertz (MHz) or faster processor (Pentium central processing unit recommended). 2. 16 megabytes (MB) of memory (24 MB recommended). 3. Hard disk space may range from between 120 MB and 295 MB, depending on your computer configuration and the options that you choose to install. 4. A full install of Windows 98 on a FAT16 drive requires 225 MB of free hard disk space, but may range from between 165 MB and 355 MB, depending on your computer configuration and that options that you choose to install. 5. A full install of Windows 98 on a FAT32 drive requires 175 MB of free hard disk space, but may range from between 140 MB and 255 MB, depending on your computer configuration and the options that you choose to install. 6. One 3.5-inch high-density floppy disk drive. 7. VGA or higher resolution (16-bit or 24-bit color SVGA recommended).
If your PC does not meet the above minimium requirements, you are bound to get errors popup installing or running software.
some high configuration as 4 gb ram can not support sp-2. there we can use sp-3. what type of problem in your compputer? it isnot clear to say solve problem
Personal computer with a 386DX or higher processor (486 recommended)
4 megabytes (MB) of memory (8 MB recommended)
Typical hard disk space required to upgrade to Windows 95: 35-40 MB The actual requirement varies depending on the features you choose to install.
Typical hard disk space required to install Windows 95 on a clean system: 50-55 MB The actual requirement varies depending on the features you choose to install.
VGA or higher resolution (256-color SVGA recommended)
Performance issues mostly happen due to requirements not being met.
Make sure that your computer meets the game requirements for GTA San Andreas. Minimum System Requirements:
1GHz Intel Pentium III or AMD Athlon Processor
256MB of RAM
8x DVD-ROM Drive
3.6 GB of free Hard Disk space for a minimal install
64MB Video Card with DirectX 9 compatible drivers ("GeForce3" or better)
DirectX 9 compatible Stereo Sound Card
Keyboard & Mouse
Recommended System Requirements:
Intel Pentium 4 or AMD Athlon XP processor (or better)
384(+) MB of RAM
16x DVD-ROM drive
4.7 GB of free Hard Disk space for a full install
128(+) MB Video Card with DirectX 9 compatible drivers ("GeForce4" or better)
DirectX 9 compatible Surround Sound Card
Game pad with twin axis analog controls (USB or Joystick Port)
Keyboard & Mouse
Your can check your system details in the DirectX Diagnostic Tool.
Click "Start", click "Run", type "dxdiag.exe" (without the
quotation marks), and then click "OK" or press the "Windows Key" and "R" (The
"Windows key" is between "Ctrl" and "Alt" keys on your keyboard) and in the
"Run" box type in "dxdiag" (without the quotation marks) and then click
"OK". You can view details of your Processor, Memory, Video Card and Sound card in the DirectX Diagnostic Tool.
the only way to improve graphics is to upgrade your graphics card and ensure that you have enough system memory and proccesor power to run the game as it should do.
If you have a 32MB or 64MB card then maybe you should go for atleast 128MB
