Garden Logo
g
greg allen Posted on Nov 04, 2013
Briggs & stratton 22" brute front wheel drive cable has came loose and i dont know where its suppose to attatch
terry barlow
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Nov 06, 2013
terry barlow
Contributor
Level 1:
New Friend:
Answers
19
Questions
Helped
7728
Points
20
Most of the front drives have a pulley . beside the pulley is a plastic arm your cable will connect to it .. like i said most models .
5 Related Answers
Anonymous
  • 79 Answers
  • Posted on Jun 18, 2009
SOURCE: have Bolens series 080 22
When you take off the carburetor initially, you should change the gasket if it tears or just old looking, your problem is in the carburetor, probably. Take it apart remembering where the parts go. There are some diaphragms or gaskets and screens on some, tiny jets and such that are inside the little "bulb" or bowl, that can usually be taken off with a 10mm wrench. They also have little fiber gaskets and a bowl gasket or o-ring that must be in great condition with no trash. Clean off with starter fluid or carburetor cleaner.
Anonymous
  • 437 Answers
  • Posted on Sep 29, 2009
SOURCE: Looking for a parts supplier to source Murray push mower 22'' deck
Well I have looked at my suppliers and they are showing it no longer available. So you may have to search around and find an old murray mower that no one is going to fix but has a good deck. good luck.
Anonymous
  • 18 Answers
  • Posted on Apr 18, 2010
SOURCE: wanted briggs and stratton 92908 manual
Find the B&S website and you should be able to download a parts or service manual.
Think it is briggsandstratton.com.
You will also need your type number (after the 92908).
heres2maine
heres2maine
  • 84 Answers
  • Posted on Jul 10, 2010
SOURCE: My flymo briggs & stratton quick silver 46d
Your carb needs to be taken apart and cleaned
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Jun 13, 2011
SOURCE: weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
How to remove drive wheels
Although I'm not familiar with this model, on some, you remove the center hub cap, and remove the bolt underneath. The wheel should slide right off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Front wheels lock up when mower pulled backwards
Not uncommon for the drive to turn in only one direction.
My daughter borrowed my lawnmower and Thanks to you, I fixed the pull start line. Now I see the front wheel self propelled line on my Briggs and Stratton Lawnmower is loose and it isn't working. It is the...
You do not have to remove anything. Some have an adjustment at the top of the handle and those that don't can be made to work by shorting the cable on the top side or handle.
Sep 27, 2013 • Garden
1helpful
I have a newer 675 Brute Briggs & Stratton, 22 " Self Propelled Lawn mower. The pull crank has seized up and I cannot start it. The blades are not tightened up, nor is there grass or weeds tangled in the...
To start the engine you must depress the flywheel brake lever, located on the top of the handle of the mower. The cable could be broken or seized disallowing you to disengage the brake. It's designed for safety reasons so that when you release the handle the engine will stop suddenly. Also, if that isn't the problem, another possibility-kinda far fetched-is that the coil has come loose and has sucked against the flywheel magnet disallowing you to crank the engine. It's located under the engine shroud. One more possibility.....God forbid....the engine was ran hard without enough oil in the crankcase and is seized. Hope
How do i ajust the governor 22 hp briggs
be carefull this one is best left to the pros if you over rev youll loose a rod
How to replace drive cable on craftsman platinum 700cc mower
I have to change the drive cable I have the end on the handle but cant figure out how to do it on the mower head
The front drive self propelled wheels stick and squeal
why is the back wheels of my briggs stratton wont stop turning
Self propell wont work when wheels are in put in grass. I have changes cable and drive belt. what could be problem?
If you take off the wheels, you'll see gears inside the wheels, check for wear and tear. If their Ok, check the cogs and pins inside the cogs on the base (or chassis) for wear and tear
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
