Check if the lens can come out completely. Just a little obstruction, can cause the lens to move back to a "safe" position. Did you check the battery, if it is still ok? Does the display give any warning?
Do you have a Kodak 3-volt AC adapter (sold separately)? You could connect the adapter and look if the camera will work then.
To make sure the battery is ok, you could take a multimeter and check the voltage of the battery. The voltage should be a little (few tenths of a volt) above the voltage on the battery, when measured with a multimeter.
