Remove the Compact Flash Cover. Located Right side next to where the network cable is installed. Remove the cover, using a small screw driver or small plastic stick depress black button gently. Called the Warm Restart switch.
When "." appears at the center on the left-hand side of the screen, enter "3" from the via 10-Key Pad. Enter the 8-digit service code and touch [END]. (Default value: 00000000) if required.
Touch [Touch Panel Adjustment] from the Initial mode screen.
Following the arrow mark, touch the four points (+) sequentially on the screen using a pen. DO NOT USE A SHARPE POINT!!!!!.
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
