Foxconn motherboard, power loss everytime i started my foxconn motherboard, the power of my CPU always loss and did not continue to boot..
SOURCE: not booting
check ur mother board power supply check the FET check all the power lines from the smpswith respective of ground with any line short check which component is primerly conected to that line replace it check the FET power IC etc
SOURCE: Foxconn Motherboards Led Boot display
Not sure what the code means, but I got it once on a foxconn board when I accidentally plugged the ps/2 keyboard into the mouse port next to it.
SOURCE: Cooler CPU Fan
Here is a list of the compatible CPUs. Is yours on the list? Did it come with the CPU installed? Steve Medley
C:\Users\Stephen J. Medley\Documents\Downloads\200811030909521886G31MV-CPU-A85.mht
SOURCE: audio drivers are gone
After some searching for that MoBO i found out that the name of your MoBo is P4M800P7MB-RS2H
And here is all avaliblr drivers for it
http://www.foxconnchannel.com/support/downloads.aspx?product_type=Motherboard&product_series=Socket+775&product_model=P4M800P7MB-RS2H&product_id=en-us0000191
It the window "Search by download Type" you print P4M800P7MB-RS2H, in the window bwlow you select >DRIVERS, then you will see all drivers there is for that MoBO, select them you want and download them
Good luck to you
If you find my answer helpfull, plz dont forget to vote!
SOURCE: CMOS Battery do no work
Just change your CMOS battery with a new one and after that goto the bios settings and update the time and dare.
After that just save the settings and then check that the warning message is coming or not.
If its coming then it means you need to change the CMOS jumper settings.
