I have Olympia typewriter Comfort, and i am using 2
Language for typing english & Arabic.
the problem is i dont know how to change the
Language when i change the rull?
how u can help me
It is "unlikely" that the machine contains both English and Arabic languages...not enough room in the memory plus keytops would be different for the 2 languages.
To change the language from Arabic to English on a KOVAC E-300 typewriter, follow these steps:
Turn on the typewriter and wait for it to warm up.
Press the "Shift" and "Language" keys simultaneously. The "Language" key is typically labeled with a picture of a globe or a flag.
Press the "Shift" and "Language" keys again to toggle between the available languages.
When the desired language is displayed, release the keys. The typewriter will now be set to the selected language.
Note: These steps may vary depending on the specific model of your typewriter. If you are unable to change the language using the above steps, refer to the user manual for your specific model for more information.
sir in your cellphone go to the menu next to the settings next to the language select the phone language settings and change the arabic language into english............
Most electronic typewriters can only be used in one language.
Typically in Nth America you have the option of getting a machine in ENGLISH, FRENCH, or SPANISH. There is no "code" to switch the machine into one of the other languages... to change language the e-prom would have to be re-programmed on the Main Control pcb.
It is unlikely you will get a typewriter with 2 languages....think of the problem of labeling the keys, as well as limited memory in a typwriter to contain both languages. Most typewriters are available in North America as either ENGLISH, FRENCH, or SPANISH. These being considered the most common languages.
1. Go to settings option.
2. Check the regional settings option to confirm the country for english language.
3. Then go to Multilingual support, in that check the country option in US english.
4 . Then go to control in Multilingual support and select English with arabic support.
