this one below is from australia
https://www.ebay.com.au/p/Running-Machine-Safety-Safe-Key-Treadmill-Magnetic-Security-Switch-Lock/26003745571?iid=282454053275&_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D20140106155344%26meid%3D255259a17a4f4034bdd90d3236d772e0%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D192235118553%26itm%3D282454053275&_trksid=p2047675.c100005.m1851
Still cannot tell what make and model....I need that to be able to tell. In any case you can buy it online....just search for the safety key for your make and model.
Error Code: Replace Safety Key (SAFE) Meaning: Safety key is not recognize Diagnostic: Replace safety key If problem persist replace upper display board
you should also try cleaning the area where you insert the key magnetic
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor. www.AtlantaFitnessRepair.com
