My flash doesnt work on my casio exilim ex z9...even if i turn it on the pictures *** out dark and the flash doesnt go off....i need help fixing it or where can i send it to get it fixed
It sounds like your sensor has problems. How old is the camera? Check the Casio site for firmware upgrades and recalls. Also search the net for others with the same problem.
The EX-Z9 doesn't have a black-and-white mode. You can convert a color picture to black-and-white using just about any photo-editing program on a computer, and this will give you better control over the conversion than any camera.
There is no DYI fix for your damaged lens, and attempting to repair it yourself will likely cause serious damage to the camera. Professional repair is needed to fix this problem.
Let the camera dry out completely. If it was not salt water it may be ok. Put it in a warm dry place for a long time. It may take weeks for the insides to get dry.....remove the battery while doing this if possible.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
I have a casio exilim ex-z60 which I bought 2 yrs ago. I've had problems with my flash going off each time I turned on and off the camera, about 5 months ago. Now the flash does not work. Need help on how to restore the flash bulb or battery in the camera.
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html I repaired it myself, but it took me a whole afternoon and lots of patience. The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :). It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again. But I guess it beats throwing the camera away. I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
