You will need some software to make your PC a device that connects to the Internet, or local hotspots and a plan from your wireless provider to use it.
Looks like your bluetooth apps might be causing the issue. Try to reset to factory settings. You will loose everything but it "might " solve the problem. If not, then it's the bluetooth module who's dead.
You can unlock your Sony Ericson LT15i form Network lock by using unlock code.To get unlock code visit Theunlockarena.com here you need to specify your country,IMEI number of your phone,Network provider to which it is locked. Then they deliver unlock code to you through mail.By using this you can unlock your mobile easily.
There you will find something like mobile network / mobile-traffic or something, I havee a norwegian phone, so I don't know what it is called on the enligsh versions.
First All Check: 1.Confirm whether same sim card is working in other h.s or not. 2.Make sure the sim slot is o.k. only try these two. 3.If all the above steps fails, check the SIM card connector pins for damage. if so try to get serviced. 4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD. u can make it jumper mean u can fix this prob with out sim card is for this contact. 5.take sim connector slight up by pin then cheak by inserting sim. 6.hot air gun on sim i.c. then cheak it. Last Option: IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service & Sim Office and Get the Duplicate Sim Same Your No From Office Oprator Problem will Solved Quickly
the charger could be faulty, the arc xperia has a known fault the logic board inside dies, the way around this is to call up the company you got your mobile phone from and see if they can replace it.
