Question about Samsung YP Audio Players & Recorders
Hi..I have a up z5f and it won't start.. just freezes at Samsung screen when turning on. . It was all finebefore iI formatted it to NTFS from fat. Now it won't even connect to my comp. Because its stuck when turning on.please help I can't format it back to fat
  • Tj Balang
    Tj Balang Nov 04, 2013
    YP-Z5F sorry for the typo... resetting the device doesn't help.. help please
Try to find the soft ware on the inter net and tranfer it on to the divice
Posted on Nov 06, 2013
Testimonial: "nah... even if i find one i can't transfer it to the device becaouse the computer cant even detect it... it can only detect the device when the device fully turns on"
SOURCE:
kjanx
  • 194 Answers
SOURCE: Samsung MP3 Player YP-Z5F
is there a reset button [pinhole] on the player??
should fix it
Posted on Feb 02, 2008
  • 7 Answers
SOURCE: RCA HC106A 4 gig mp3 player
u might have to reformat it because mine did the same thing and sombody told me how to reformat it all u do is plug ur mp3 into ur computer with ur usb cord then go to a folder called 'my computer' then there should ba an icon that looks somthing like an mp3 and if u dont see it at first give it a few minuets then when it dose show up it should have the name of what ur mp3. RIGHT CLICK on the icon then click on FORMAT and it should reformat it.It might not work though oh and if the name of ur mp3 isent there but the icon is and were the name of ur mp3 should be it will say something like MTP device like it did 2 me when i tried to reformat mine.If that dont work u could try to reset it by holding the power button for 10 secends.Those might not cause neither 1 did 4me.good luck!!
Posted on Mar 30, 2008
SOURCE: Samsung YP - Z5F
ahh this problem is really simple, as i just fixed my Samsung YP-Z5F. The solution is really simple, just press the reset button. Its located at the bottom of the mp3 player. just use a pin or something to poke it and then turn it on again. wait a few seconds. and it should be working all good again =)
Posted on May 27, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: I still can't format please help me!
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
  • 79 Answers
SOURCE: Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Posted on Jun 20, 2009
USB EXTERNAL HARD DRIVE
What format has the drive been formatted in? NTFS or FAT? If it is NTFS it won't work, NTFS is the default format of most modern OS. You need to back up the data and re-format the drive to FAT format and copy the files back on to it.
Mar 09, 2012 | Computers & Internet
What format should I chose to grab it to a PC?
This will depend on which type of computer and operating system you have
if you are referring to formatting your hard drive to a specific format file system NTFS or FAT choose the Ntsf file system is more secure Ntfs is more powerful than Fat or Fat32 and includes features required for hosting Directory as well as other important security features . You can use features such as Active Directory and Domain - based security only by choosing Ntfs your file system Its easy to convert Partitions to Ntfs . The set up programs conversion makes it easy whether your partitions used Fat or Fat32 or the older version of Ntfs .This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive.
hope this helps you
Sep 03, 2011 | Computers & Internet
I formatted a 16GB sony produo mem stick on my laptop using Win XP II. Now my computer or camera or PSP can't detect the card
Put the card back in the computer and format it using FAT (not NTFS) format. In the format menu, you'll see the file system pull down option, choose FAT and format again.
Feb 20, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Drivr
How have you formatted(ntfs/fat/fat32)?
Most players use the fat file system, and won't work using ntfs or fat32.
Have you wiped the firmware?
The firmware is the players operating system and needs to be there to run it.
If you run the firmware upgrade program, if you have it, you may be able to recover the player.
www.samsung.com
try the site for the firmware upgrade program.
Aug 27, 2009 | Samsung YH-820 MP3 Player
I cannot copy files FROM my Western Digital 500GB
Check the file system of your hard drive. If your PC is recognizing it, check if its a FAT or NTFS. If it is NTFS then you have to reformat it using your Mac and choose FAT. Mac OS recognizes NTFS as a read only drive. If you plan using it with your PC and MAC you should format it using your mac and choose MS-DOS in disc Utility. You cannot format the drive using your PC Computer with a FAT file system because of the capacity. Only Mac can format it with a FAT file system.
Aug 23, 2009 | Western Digital My Book Essential 500GB...
Card lock.?
Friend dont worry it so simple
Insert u r card into card reader and then change its format
Up to
Fat or Fat 32 Into NTFS and format it if it is formated then it will be ok
Jul 25, 2009 | Samsung Digimax S630 Digital Camera
Xp
Hi There,
I just experienced the same problem you did concerning the partmgr.sys blue screen error. I am installing Windows XP Pro SP2 on a pretty old Dell Latitude LS (upgrading it from Win 2000). The XP installation disk gives me the option to format in NTFS, FAT, and both formats in a "quick" mode. I usually do not recommend using the quick mode, however, after trying both NTFS and FAT and receiving the blue screen, I decided to try NTFS (quick). That has allowed me to actually get further into the installation, so you may want to try that.
May 27, 2009 | Microsoft Windows XP Professional
I/O DEVICE ERROR
U might have formatted it the Yepp player to NTFS format. Format it to FAT. Should work.
Nov 25, 2007 | Samsung YP-U2X Digital Media Player
How can I format the mp3 player?
Windows only formats in fat32 or ntfs, only Win95 or 98 formats in fat, so you may have to go to the manufacturer web site and look for a formatting programme. Otherwise, there may be a factory reset or similair on the mp3 player, select this and everyting should be deleted.
Mar 16, 2007 | Samsung YP-T7X MP3 Player
56 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
