Nokia 101 Dual Sim Mobile Phone - Unlocked Torch 2 Twin Sim Cheap - N101 - Black Logo
Angelo Cortez Posted on Nov 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you relocate my security code ? IME1 :
Can you relocate my security code ? IME1 : 356342054879644 IME2 : 356342054879651
Rinoo Kumari
Level 2:
  • Nokia Expert 2,973 Answers
  • Posted on Nov 04, 2013
Rinoo Kumari
Nokia Expert
Level 2:
Answers
2973
Questions
0
Helped
642535
Points
712
Once the security code is lost the firmware has to be re-installed. Please do so using Nokia PCSuite.
3helpful
2answers
I have a 2002 Kawasaki Mean Streak 1500 I'm customizing it can the rectifier be moved so it's not just hanging there.
Absolutely, the rectifier on your Kawasaki Mean Streak 1500 can be repositioned during a customization project. The rectifier is a crucial part of the motorcycle's electrical system, converting alternating current (AC) from the stator into direct current (DC) to charge the battery and power the bike's electrical components.
While relocating the rectifier, it's important to consider a few key factors:
  1. Space and Mounting: Assess the available space on the motorcycle to find a suitable location for the rectifier. Ensure that the new position allows for proper mounting and secure attachment without interfering with other components or the bike's functionality.
  2. Heat Dissipation: The rectifier generates heat during operation, so it's essential to relocate it to an area with adequate airflow for cooling. Mounting it in a well-ventilated area helps prevent overheating issues.
  3. Wiring and Connections: When moving the rectifier, ensure that the wiring can be appropriately rerouted to reach its new location. Take care to maintain proper electrical connections and ensure a secure, stable wiring setup.
  4. Protection: Consider adding protective measures, such as shields or guards, to safeguard the relocated rectifier from road debris, water, or other potential hazards.
Modifying the placement of the rectifier may require custom brackets, mounts, or fabrication work to secure it in the desired location. It's crucial to execute the relocation carefully, maintaining proper electrical connections and ensuring the rectifier's safety and functionality.
If you're not confident in performing these modifications yourself, consulting a professional motorcycle mechanic or technician with experience in customizations can be highly beneficial. They can offer guidance, expertise, and ensure that the modifications are carried out safely and effectively.
tip
Gateway LCD monitor EZTUNE theft protection problem
You need to install EZTUNE but you need to go here first:
Portrait Displays' Theft Deterrence minimizes theft or unauthorized relocation of your display. Theft Deterrence does not prevent the display from being stolen, but hinders the operation of the display once it is removed from the 'Theft Deterrence enabled' host computer.
This site is provided for you to securely store your PIN in the event you should need to retrieve it at some point in the future.
Please select from the following options.
Change your PIN. https://pinreg.portrait.com/change_p...=dtune&OEM=gwy
Forgot your PIN? https://pinreg.portrait.com/remind_p...=dtune&OEM=gwy
GatewayShield™ Security Available
Protect your hardware using the EzTune™ Anti-Theft Software and reinforced lock slots. The slots, paired with a cable lock, physically anchor your display to a secure fixture. The software keeps the monitor secure using a unique PIN code. In the event the display is removed from the PC without the code, its full functionality is disabled.
on Apr 14, 2010 • Computers & Internet
How do i change the extention number or port number when i move my Nec Electra Elite 192 phones to different wall phone jacks?
Look for the Elite Attendant User Guide
Also call your vendor for the password
SET RELOCATION MODE
Set/Cancel using the Access Code:
1. Press the
Feature
key.
2. Dial Set Relocation Mode code
84
2answers
What are the different categories that Involved in Business of Removals??????
Removals Business Involved services of House Removals, office Removals, Man And Van Removals and some of them also provide cleaning and garbish removals service.If you want to see more then must click on thse removals websites.Removal Companies
Removals Wimbledon
3answers
1helpful
4answers
Phone security nokia 2626 imei no.35415402788294
hello! so you mean you are trying to locate your phone security number? the best thing that you should do is to go first to your phone setting and try relocating it and default your phone security. in that way, it will allow your security no. to be turn off.
1helpful
Dll user32.dll problem
Certain programs may not start after you install security update 925902 (MS07-017) and security update 928843 (MS07-008) on a computer that is running Microsoft Windows XP with Service Pack 2 (SP2). Additionally, you may receive an error message that resembles the following: application_executable_name - Illegal System DLL Relocation
The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occurred because the DLL C:\Windows\System32\Hhctrl.ocx occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL.
RTHDCPL.EXE err
Error Message after Installing Security Updates 925902 and 928843 This afternoon (April 3rd, 2007) my Automatic Updates alerted me about a couple updates I needed to install, so I did. Upon rebooting the computer though I was confronted with the following error message
"RTHDCPL.EXE - Illegal System DLL Relocation"
"The system DLL user32.dll was relocated in memory. The Application will not run properly. The relocation occurred because the DLL C:\WINDOWS\SYSTEM32\HHCTRL.OCX occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL."
Cause of Error Message
Turns out this error occurs when the Realtek HD Audio Control Panel by Realtek Semiconductor Corporation is installed. This is my built-in sound card on my computer.
The HHCTRL.OCX file that is included in the Security update 928843 and the User32.dll files that is included in Security Update 925902 have conflicting base addresses. When Windows loaded the HHCTRL.OCX file before it loads the User32.DLL file, the problem occurs.
The error occurs when the following third party programs or applications are installed on a computer with Windows XP Service Pack 2 installed.
ElsterFormular 2006/2007
TUGZip
CD-Tag
Microsoft now has released a patch to correct the problems, you can go to the following link to download and install the patch for the patch :-)
http://support.microsoft.com/kb/935448
Can not get code
Enjoy!
PCRU45-001-OTGL-2F9B-01C0-S271-2A5E
Please do not forget to rate me! Thanks
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
