Cell Phones Logo
C
Candy Oliveras Posted on Nov 03, 2013
IP Address on AT&T Router keeps failing
This is what is specifically failing during the Connection Check: Continuity check to 6rd BR - FAILED. What do I do to fix this? Also, new iPhone 5c will not connect to the network even when trying to connect manually. The phone keeps saying incorrect password, but will work on every other device.
  • mercy huerta
    mercy huerta May 03, 2014
    The same thing is happening to me but with my iPod 5 it saus "incorrect password" and i dont know how to fix it
5 Related Answers
Anonymous
  • Posted on Feb 14, 2008
SOURCE: LG Viewty pc connection problems
What you need to do is click on the top right corner of your LG Viewty phone which will show all applications running. If you have an 'Unknown' app, click on this.
The problem is that the user guide for the phone is running and you need to click on 'Unknown' and finish the tour or exit.
This will then alow you to connect to your pc;-)
billyd111
  • Posted on Jun 07, 2008
SOURCE: Internet connection failed but IP address obtained.
OK IF YOU HAVE PS3, and you get the ERROR DNS while trying to login into PSN, all u need to do is, shutdown the console, then restart it by holding down the ON button on the PS# not the controller till you hear 2 beeps, then try to login again, should work.
Anonymous
  • Posted on Dec 20, 2008
SOURCE: Message sending failed....
Oh my god. thankyou to the person who mentioned deleting sent items! it works! even 02 couldnt tell me that.
thankyou
DELETE SENT ITEMS!!
Anonymous
  • Posted on Feb 08, 2009
SOURCE: IP Address keeps failing on my Xbox 360
ok ive had this problem since christmas i just got it up last week .soo do cycle power turn off everything for 10 seconds when its back on everybody makes this mistake make sure that the usb kord is out that idk why it ***** it up soo take that out and go to setting put it on automatic and restore factory settings
Anonymous
  • Posted on Mar 24, 2009
SOURCE: Cant connect LG Renoir via USB, connection problem
I get this all the time and it is really annoying.
What I do to solve it for me is to is to tern all my mobile application off and then reconnect the USB cable.
To close all open applications: press the white hard key (in the middle of the red and green), and you customisable menu appears. At the top of the screen is a grey tab with a dark grey triangle (like a play button), press this and you see all (if any phone application are open), press the end all button on the screen. Then to confirm action pres yes to stop all tasks.
Hope it solves you problem.
SS
Hp 1606 after updating firmware it is same issue, status:- Initializing static ip 0.0.0.0
is this a P1606 printer, left off the "P"
?is it to much to say printer, ? so we dont have to look up wrong typed models?
?reset the printer first? ?
?what way are you using said printer
?nO PC Stated.
?no NO OS stated.
?did you load fresh all HP software for this printer?
?no Connection options stated,.
?I guess USB connections are not any good?
?so you read page 28 in your manual (connections to ethernet)
?to your router wired with CAT5/6 cable?
?and this fails,
?the
ip 0.0.0.0 (MEANS DHCP FAILED) OR FAILED TO SET A RESERVED ip ADDRESS TO THE PRINTER. IN THE ROUTERCOVERED IN PAGE 29 IN YOUR MANUAL. BTW.
?RESET THE PRINTER, AND TRY USB , IF THAT FAILS
?YOU MESSED UP THE FIRMWARE UPDATE.!
?IF usb WORKS , RESET THE PRINTER AGAIN
?THEN read page 28 and own for Ethernet.
?in all cases like this reset the printer first OK?
?some models have optional wireless wifi
?is that what you are attempting ?
?http://www.manualsdir.com/manuals/600884/hp-laserjet-p1606dn-laserjet-pro-p1560-laserjet-pro-p1600-series.html
?here is your official page the manual is there.
?reset it and connect 3 different ways. if all options present.
?https://support.hp.com/us-en/product/hp-laserjet-pro-p1606-printer-series/4110408
2answers
I can't sign in Y!M clicked troubleshooting and I got this Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the...
Bruno
Start your troubleshooting with a clean browser
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_cclean...
On the sign-in page click Messenger > Connection Preferences - make sure there is nothing untoward in the lower 2 boxes - if incorrect make changes using the drop-box options > OK
Copy this Yahoo secure site URL
https://www.yahoo.com/
Open Yahoo Messenger > Tools > Internet Options > Connection tab > LAN settings > Uncheck everything then check 'Automatically detect settings' and 'Use a proxy server' > Advanced > Paste the address in the secure box and type 5050 in the port box > OK
Sign in.
Hope this helps.
Router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Netgear Random Internet Loss
have you tried setting a static ip address?
1helpful
PS3 (80GB) Obtain IP Address : Failed, Help?
Try swapping the ends of the ethernet cable between your PS3 and the router. Otherwise, try a different ethernet cable. Also check that there are lights on by your ethernet port on the PS3 and the router.
Cant get the wireless connection through the AP router
first check ur computer IP address (if not getting from DHCP then try static IP address) & default gateway.
Check to make sure that your router has gotten an IP Address from your ISP. Because you PS3 is telling you that it has an IP from your router. This means that the Router to PS3 connection has layer 3 connectivity, but what about from your router to your ISP? check that in the router by logging into the router's web page and going to the status page it should have your information from your ISP if it does not make sure that the main page is set to the proper settings either get IP automatically (Cable Modem) or Get PPPOE (DSL) connection (Make sure that your password information is correct to).
Now after checking these items make sure that you set the router up as the DNS for your network buy setting this on the status page then in your PS3 (set the DNS setting to point to your router, and set your router up as a caching DNS server).
Then power cycle the router after saving everything, and power cycle your PS3 after setting everything. This should clear up your problem.
Thank you,
Shuttle83
Cannot connect the the Zyxel page to configure my Embarq router.
you can check the router ip address by going to network connections in control panel and then, right click on connection icon>status, then support tab, there will be the ip address of your pc and the default gateway address which will be your routers address.
If you still cannot get into the router, there will be a hard reset button on the underside or rear of the unit.
4answers
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Top AT&T Cell Phones Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
