SOURCE: Door won't open
If you open the detergent dispenser and feel along the front edge behind the removable cup there is a coloured cord usually red or green in colour this in an emergency door release, by pulling on it firmly the door will unlock.
SOURCE: washer door latch stuck, can't open
ahh..time for "Q" from 007, eh? this interlock feature is a relay controlled issue. Seems that your washer is telling you that it's closed. most likely a relay replacement in control panel area.
SOURCE: Washer will fill but won't start cycle
you need to take the 2 lid switch wires from the lid switch and wire them together this will bypass the lip switch,should fix it,let me know-mike
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
