Exercise & Fitness Logo
Kellie hammer Posted on Nov 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sportscraft treadmill it come p. fine run for a few seconds and goes off. The screen had a 3 on it when it goes off. The fee seconds it does run it seems fine
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Nov 04, 2013
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4077929
Points
34431
I have a sportscraft treadmill it come p. fine run - 7eef0c0f-9fee-4743-8c0c-d60deca9fbdb.gif1) tight and clean the upper and lower connector
2) tight and clean the ribbon cable for display board
3) adjust the Reed swtich , tight and clean and test for faulty or open
see the diagram attached.
4) lube the deck belt see the video.
God bless you
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Aug 22, 2009
SOURCE: e3 error and treadmill shuts off
One of the safety sensors is reading false. Mainly times this is just a cleaning issue. Remove the lower cover and look for a pickup sensor either,both on the end of the motor or end of the front roller, look for the one that is a disk, should have a sensor with wires leading to the circuit board. try blowing it out with a dust blower or carefully vacuum, it can get bumped and be out of alignment.
vpaaf
Howard
  • 115 Answers
  • Posted on Oct 11, 2009
SOURCE: treadmill tx400 wont work for llonger then 6 seconds
Sportcraft tradmill are very safe. First check and make sure there are no recalls on you unit. Do that on line or call Walmart where you most lickly got you treadmill. Try lubing you deck wich is under the belt. This is something that needs to be done to stop friction... Frition may have worn down the motor. Get back to me
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Anonymous
  • 83 Answers
  • Posted on Apr 30, 2010
SOURCE: bogs down
Sounds like either the belt is loose or the belt/deck need to be lubed.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
To lube the treadmill, use silicone spray and spray between the belt and deck on both sides. I hope this helps. Let me know if you have any other problems.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Oct 12, 2012
SOURCE: My sportscraft treadmill TX4.9 shuts down when it shows 3 on the speed
LUBE the deck belt,this happen because the lack of maintenance. may be is time to exchange the drive belt.
2) LUBE the rollers bearings. too
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor , if there are NOT the board is faulty. see the b. diagram attached, see my personal TIPS.
God bless you
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Oct 17, 2012
SOURCE: my sportscraft treadmill stops and displays a 3 on the monitor,what would cause this?
please LUBE THE deck belt, this happen because the lack of maintenance. shut down.for protecting the electronic system
2)LUBE the rollers bearing too very well
3) test the input voltage motor, if there are the motor need repair.
4) adjus the REED swtich, see the diagram , clean it, an tight any connector, or plug.
God bless you
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Tx 5.0 rc treadmill by sportscraft, manual
Did u find out the problem? Mine just started doing the same thing.
1helpful
My sportscraft treadmill stops and displays a 3 on the monitor,what would cause this?
God bless you
A backwards E appears on my treadmill model 3-1-04-050 FH what does this mean?
Read your instruction manual, section troubleshooting for indication.
However you must adjut THE reed switch, see the diagram attached, clean, and tigh the connector wires very well. God bless you.
Run the software calibration for diagnose, and troubleshooting too.
2helpful
2answers
Treadmill tx400 wont work for llonger then 6 seconds
Bogs down
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
