Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
Apple g4 aluminium
My g4 got dropped and is now silent but still working. i changed the sound card but still no sound. have noticed damaged capacitor near the max 1717 chip. what is this chips function, what is this caps value
    Novelist:
    Champion:
  • 382 Answers
What sound card are you using? It has to be external for you to switch it. When a computer is dropped, the hard drive and logicboard are under severe danger. The drive is constantly spinning anywhere between 4200 and 10k rpms. If the logicboard endures any shock there could be endless possibilities to failures in addition to them being intermitten. Can you specify which G4 you have, in processor speed and machine/display size? And I take it when you mean " no sound", you also mean no Apple start-up chime when you boot the machine?
Posted on Oct 19, 2007
SOURCE:
2006 powerbook G4. my screen will get glitchy and i can see multi color squares and lines randomly on the screen. when i move a window the pixels chase and outline my movements. any ideas?
sounds like the video card is dying. I was able to hold off on one dying by downloading a fan controller that kept the machine cooler, but with the age of the G4, it's likely damaged. Consider replacing or the fan controller.
Jan 19, 2014 | Apple G4 Computers & Internet
Tip
Computer randomely shutting down
As a 25 years experienced technician, some times I have clients who come to me saying " I have a computer that keeps shutting down randomely " they had it checked by some tech. and he can't find a clue what's going on, even after changing the power supply...
The reason is that the tech did not noticed the swollen capacitors on the main board usually around the CPU or the RAM...
Conclusion! if your computer is randomely shutting down, befor changing any hardware, open the box and check for the physical state of the capacitors (round aluminium cans covered in a plastic shrink) the top are suppose to be FLAT not about to burst.
They can be changed by a proffessional tech. with good tools and lots of patiance (not to damage the feed trough's on the board)
on Dec 29, 2010 | Computers & Internet
Powerbook g4
If you have the operating systems disk, you can boot from the disc, and once the setup come dump, choose password reset from the "utilities" drop down menu. Change your password, shutdown, and reboot.
Nov 03, 2013 | Apple PowerBook G4 Mac Notebook
My powerbook g4 no longer recognize my builted in airport, have no airport now. The only way to make my g4 work in hook an either net cable to my g4 into my router. Makes my laptop very stationary, what...
What I would suggest is reseating the airport card as it may be the card has come loose or the cable is not connected properly. The following support page on the apple website will tell you how to do it.
support.apple.com/kb/HT2617
Failing that you will probably have to buy an new airport card or a wireless usb adaptor. You should be able to pick one up from ebay fairly cheaply.
Hope this helps.
Apr 17, 2011 | Apple PowerBook G4 Mac Notebook
My older G4 white 12"macbook laptop drops the wireless connection
try to update the Mac Os x and also the airport card drive.This can solve the issue
Feb 20, 2010 | Apple MacBook Mac Notebook
I have a Escort 2000 Peavey P A System. The fan is making a noise when I switch it on, but as soon as it ''heats up'', the noise stops. Is it because of the cold weather or is the fan giving notice?
It might be giving notice, it might have some loose screws, but then again, it might just need some oiling.
There's probably a sticker on the rear side of the fan (where the power wires come out), remove it, underneath you'll see an aluminium cover near the center. Take this cover off with a pointed knife or similar, it should come off with just a slight force and you should now see the axis fixed in place by a clamp.
You just need to put a drop or so of oil, just make sure it reaches underneath the clamp into the bearing/bushing and if the bearing/bushing was just a bit dry or dirty and if it's not really damaged then the fan shoud now run quietly.
Put the aluminium cover and the sticker back in place, try it out, if it's silent, you win, if it's still giving notice then it should most probably be replaced.
regards
3rq8 (Triarcuate)
Aug 03, 2009 | Peavey 00511800 Escort Portable Sound...
Thanks for the help!
That sounds like it would fix it. Have you recently updated the memory in the imac? It may be incompatable. Otherwise it may simply have become faulty over time.
Please make sure that before you open up your imac, you're not voiding your warrenty. I know that the aluminium imacs allow this, but i dont think the G4 versions do.
Hope this helps,
Nathan.
Apr 13, 2009 | Apple iMac G4 Desktop
CMOS battery change G4 Ibook
I noticed this is written over a month ago...are you still having problems with the CMOS?
Sep 08, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
64 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
tylerbell49
Level 1 Expert
Peter Dragonetti
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
