Whirlpool LER4634J Electric Dryer Logo
Posted on Sep 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Access to blower fan on whirlpool dryer?
On a "Kenmore" Whirlpool combo waher/dryer(110) unit mod #110.887322793 I need to get the blower fan out to replace it.  When I take the back off and the drum out I see the fan is inside a black matal "tube" housing with crimped over edges.  Do I need to unbend these edges to get the two halves apart? Is there an easier way I'm not seeing?  Many thanks.
Sal De
Level 3:
  • Whirlpool Master 2,699 Answers
  • Posted on Sep 15, 2017
Sal  De
Whirlpool Master
Level 3:
Answers
2699
Questions
0
Helped
1003152
Points
8029
If you have the back off you have to remove the air duct to get at the blower wheel,there are some screws that hold it on.go here and look at dryer bulkhead and it will show you a picture,you have to spin the blower wheel off of the motor shaft,if you look at the blower wheel it will show you what way to turn it to get it off.
http://www.searspartsdirect.com/model-number/11088732793/0582/0152000.html?searchType=modelSearch&q=110.887322793&searchTerm=110.887322793
5 Related Answers
A
Anonymous
  • Posted on Feb 01, 2008
SOURCE: whirlpool calypso dryer
clips at top of bottem front panel push w/ screwdriver and pull
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Feb 26, 2008
SOURCE: Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
lenwest
Len West
  • 150 Answers
  • Posted on Jan 30, 2009
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
jonniewalker
Starnley Johnwells
  • 1031 Answers
  • Posted on Feb 09, 2009
SOURCE: whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Mar 02, 2009
SOURCE: Taking apart Whirlpool dryer
below the door the panel is held onto the frame with clips. Use a putty knife to get it out yer way.77d0e23.jpg
GAS DRYER INFO
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Open front panel on kenmore 77902791 dryer
Hello Barry Bosik,
Depending on the controls location...
(I think yours is REAR... you have a PARTIAL Number)
Most DRYERS open pretty much the same...
Put masking tape on a putty knife...
(to protect you finish) and push the release spring...
>> About 1 1/2" (inches) from the corner at front
straight back ( do not PRY )... Lift the corner & repeat
the push & lift on the other corner.
ELSE
just watch the VIDEOs
... These folks like to remove the top
(I don't... if it is a belt or fan... I will go the EXTRA MILE
to rig rope or cord to hold the lid...
>> Tape the DOOR SHUT.
>> A couple more screws loosens top front leans out
Here you might want to snap a picture
of how the front BOTTOM keys together...
You must make sure
it is properly fitted during reassembly...!!
Rather than point you to my favorite sire
(I will include below)... I am going to direct
your to SEARS... searspartsdirect.com
(a bit on the $$$$ side).
Water Filters Lawn Garden Appliance Parts
Parts houses (SEARS included) now have VIDEO
help... Unlike the "STUFF" on the general internet
These REPAIR videos are a good and decent
representation of the work required...
appliancepartspros
http://www.appliancepartspros.com/whirlpool-drum-felt-seal-280114-ap3790434.html#autoplay
repairclinic
Kenmore Dryer Model 110 77902791 11077902791 110 77902791 Parts
3 videos
Kenmore Dryer Blower Wheel WP697772
partselect
Whirlpool 661570V Drive Belt PartSelect
I need to replacement fuse for Kenmore electric dryer. model number 110.62212101
Sears Parts Direct lists all of the parts for the 110.62212101 here: www.searspartsdirect.com/model-number/11062212101/0582/0151200.html . If you need the dryer thermal fuse (3392519), that is part 9 on the Bulkhead diagram. The direct link to the part is http://www.searspartsdirect.com/part-number/3392519/0026/110.html?modelNumber=11062212101&categoryName=Residential%20Dryer&brandName=KENMORE . They also sell thermal fuse kit, http://www.searspartsdirect.com/part-number/3977393/0026/110.html?modelNumber=11062212101&categoryName=Residential%20Dryer&brandName=KENMORE .
Other vendors will have the part since the dryer is made by Whirlpool. Whirlpool used the parts in many models.
I hope this helps.
I have a whirlpool dry mod#5636 in my home I have 110 the cord on the dryer is for 220 can I change it to 110 and will it work right..
No it will not,dryers with 110 volt plugs heat on gas,220 dryers heat with electric,putting a 110 vac plug on dryer for 220vac,the motor will run but it will not heat
your 2 options are
1) have a electrician come and run 220 vac circuit
2) purchase a gas dryer
3helpful
2answers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
1helpful
What year was electric kenmore dryer 110. 86574110 65741 made?
The year and approximately the month Whirlpool and Whirlpool-made appliances can be determined from the serial number. The second letter in the serial number indicates the year while the first two digits of the number indicates the week the appliance was made. Locate the serial number then click on the link below for the details on how to determine the age of your Whirlpool-made Kenmore dryer.
Determining the Age of Dryers and Washing Machines Made by Whirlpool
7helpful
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Trying to access the blower fan on a Kenmore 80
Remove the rear panel.
Then remove the screws that secure the blower fan vent on the left side to access the blower wheel.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
