When I plug in or put battery in the vacuum all it does is make one clicking noise and won't run. I had the switch checked and that seems to still be good.
I'm also having the same problem. When I turn the vacuum on I get one click and nothing else. Any ideasI'm also having the same problem. When I turn the vacuum on I get one click and nothing else. Any ideas
You can't post conmments that contain an email address.
may be the carbon brushes are short or motor connectors have become bad connection by moisture and dirt by use temporay a wrong filter sometimes its a very light and simple motor johnson motor with hammer brushes DeWALT DC500 Type 1 Vacuum Parts
there is a float ball or reed that closes off the exhaust port inside the canister, to prevent water from filling too high when used as awet vac. If lodged or trapped it will prevent suction or discharge in wet and dry modes. look at the housing that the filter attaches to and you will see it. if it doesnt rattle when you shake the unit up and down, it is stuck; otherwise, you must not be spinning the fan blades.
I had the same problem and traced it down to the on/off switch. I sprayed some electical contact cleaner down inside the switch and now it works normal. Hope this helps.
