SOURCE: I have an Acurite 822-RX thermometer that shows HH
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
SOURCE: Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in. Unfortunately this also messed up the clock's time and date. This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
SOURCE: Sony KV-35S66
I have had a similar problem for three years with my KV-35S66 (purchased 12/99). With my TV, I get no picture and the red LED flashes, but it doesn't cut out -- it will keep on blinking. Sound comes through fine.
My fix is to put a space heater right in front of the TV for an hour or two, then turn the TV on (or off and then on again).
It appears to be something in the electronics that needs to be warm to work properly (loose connection that expands when heated?). Once the TV is on , the TV stays warm enough to keep the picture (i.e., you can remove the space heater). I just leave the TV on constantly (it is in the basement and doesn't bother me, and my satellite displays a screen saver). TV is otherwise fine and the electric cost is much less than buying a new TV.
You could turn off and then heat up when needed, I suppose, but that takes some planning ahead.
SOURCE: astra remote car starter problem
your remote starter is in valet mode, the door lock will still work but no remote start, try pressing the trunk button 3 times, if that doesn't work turn the ignition switch on and off 5 times
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
