Question about Toshiba 32D1333b 32" Hd Ready Led Tv With Freeview And Built-In Dvd Player New For 2013
When I change channel on my toshiba 32d1333b 32" television, on the section at the bottom of the screen where the current programme and the next programme normally appear when you change chamnel, nothing is appearing. I have to press "info" on the remote to find out what is on and what the next programme will be. Any ideas on how to fix this so that the current programme and next programme will automatically come up? Thank you.
    Top Expert:
  • Toshiba Master
  • 12,223 Answers
Go to the MENU, and restore to the factory default.
God bless you
Posted on Nov 04, 2013
SOURCE:
What can be done to repair picture to my TV
Vertical scan output section circuit should be checked. Contact any service technician.
Aug 30, 2014 | Toshiba CF32H40 32" TV
Toshiba CF32H40 32"TV shrinking picture with solid black on bottom. What causes this and can it be fixed?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
I have retuned my parents tv but now the digital (freeview) channels do not have the correct channel numbers and I cannot find anything in the manual as to how to change them. For example, freeview channel...
It sounds like the TV has re-mapped the channels incorrectly. You possibly can contact Toshiba to see if there is a firmware/software upgrade that will fix this issue. If there is you may be able to download the software off of their website and install yourself. Just make sure if that is the case follow the directions carefully. Please take a few moments to rate my answer. Thanks..
Nov 19, 2009 | Toshiba 32WLT58 32 in. LCD Television
Digital channel mix up
your cable company is moving the channels around. they are doing a major upgrade
Trouble tuning in empty dtv channels
Just go to the main settings. You will see an "autoprogram" option. Select this and it will scan all available channels and delete non-airing channels
Jun 22, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Screen is frozen and displaying," this is an encrypted channel." I unplugged it for a few hours, turned off and on....what do I do next
hook up your sat/cable box and reset the tuner; place the set into "setup" then: "add channels" the tuner will look for and install active channels
Apr 25, 2009 | iLO 3200 32 in. LCD Television
Blackout area on screen
Make sure the TEXT and CAPTION options are turned off.
I am not sure about the Sonny's, but on my Toshiba a black box appears when I inadvertently leave one of the close captioning (CC) on for text or captions on (such as CC1, CC2, etc.).
Feb 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen partially black
BAD CAP IN THE VERTICAL SECTION,NOT TO MUCH TO REPAIR.
Dec 15, 2007 | Toshiba 32AF42 32" TV
Toshiba 32D1333b 32" Hd Ready Led Tv With Freeview And Built-In Dvd Player New For 2013 Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
