I started to sew with the needle in the left position but the foot I had on was a center position. The needle stuck in the foot which I was able to get off, I can **** the needle unit manually but the computer won't change positions based on the stitch I choose. How can I fix this
SOURCE: Brother Innovis 4000 D stopped sewing
These machines are known to freeze up in the needle bar crank, even when only a couple of hours old. If it is less than a year old, a Brother certified service center will fix it under warranty.
SOURCE: I was given a brother
Hey RM check the bobbin area and see if the hook area has any thead cought in it you might have to remove the bobbin case to see it
SOURCE: sewing machine 'popped', and needle is hitting
Adjust the metal plate to fix the needle hitting problem.
SOURCE: where is the control for the needle position? Mine
dial on top right side put around 3 it should center it
Testimonial: "Thanks so much, your help worked!"
