Question about Jenn-Air JJW9830D Electric Double Oven
My jenn air dual oven timer, temp lights are going out
The lights on my oven are dimming and when the oven is on you can't see anything (temp nor timer). any ideas? bad light, fuse etc....?
    Scholar:
  • 54 Answers
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by Briangem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF.
Posted on Aug 12, 2009
SOURCE:
Jenn-air expressions wall oven clock went dim, now out completely
This may be no help at all but;
Similar ovens have had problems with timer components going bad (overheating) and causing this problem.
First contact Jen- air customer service about a recall or replacement timer board, if that doesn't work remove the timer board and look for a discolored or leaking capacitor, These capacitors are less than a buck as opposed to over a hundred for a replacement board. If you don't want to solder it yourself find your friendly local geek from the radio or electronics club or get a recomendation from the local electronics parts house,
Nov 08, 2009 | Ovens
Double oven (WW30430B) got the similar display dim/disappear prob
If you haven't already, replace the capacitors on the clock module. I had the same problem with a similar oven. See this link for more info:
http://www.badcaps.net/forum/showthread.php?t=7902
Aug 23, 2009 | Jenn-Air JJW8530C Expressions Collection...
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn Air JJW8530C stopped working
can you hear audible tones form the machine when trying to set?? and just hte display has dimmed( amore normal complaint). all functions are working just the clock/display has dimmed to non readable state. if thats the issue youll need to replace the display part number 71003424 retails for about $165
Nov 04, 2008 | Jenn-Air JJW8530C Expressions Collection...
No display, No beeps, No heat
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Jul 15, 2008 | Jenn-Air JJW8530C Expressions Collection...
Light for the temp. & time very hard to see can it be made brighter?
then you will have to replace the eoc the electronic oven control as long as it was working id use it till it wasnt then replace it
Jan 19, 2008 | Jenn-Air JJW8530C Expressions Collection...
Electrical Jenn Air Oven control panel ..
theres no fuse. the display needs to be replaced. this is a common problem on maytag and jenn-air ovens
Nov 26, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JJW9830D Electric Double Oven Logo
123 people viewed this question
Top Jenn-Air Ovens Experts
Craig Butler
Craig Butler
Nathan Van Boven
Nathan Van Boven
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
