My manual is packed & i need to do some mending.
cannot remember how to refill the bobbin or thread machine
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
To wind a bobbin, guide the thread from the spool post to the small round tensioner /guide on the top of the machine.Wind a few turns of thread onton the bobbin.Place the bobbin on the bobbin winder post. Release the hand wheel and wind the bobbin as full as you like or until it stops. Remove the bobbin,place it in the bobbin case and insert the bobbincase into the hook.
Beginning with the spool, guide the thread through the thread guides to
the tension assembly. Pull the thread through the tension assembly and test it
to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way.( If you load your bobbin
case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT.
There are some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
sewman7
