Starter motor relay , transmission range switch , wiring ! Do you know what a wiring diagram is ? How to read one ? How to use a DVOM - digital volt ohm meter ?
How to voltage drop test starter motor circuit
do you know what a relay is ? how to test one .
VEHICLE RELAYS Operation Diagnosis
You can view free wiring diagrams here http://www.bbbind.com/free_tsb.html enter the vehicle info. year , make , model , engine size . Under system click on engine , then under sub system click on charging system . click search button ,one link will pop up , click on it . First diagram is starter circuir . If starts jumping at the starter the problem is on the control side . trans range switch , starter relay ,blown # 6 40 amp fuse in the under hood fuse / relay center .
SOURCE: 1981 Corvette will not start
The neutral safety switch is located in the shifter housing.
Here is a link to a good article on this topic, that would beat an explanation from me.
Brian
Yes, it sounds like the NSS is the culprit.
SOURCE: fuel pump?
You need to see if your mechanic replaced the wiring pigtail to the pump. The pigtail on those have a habit of shorting out. If the pigtail is in good condition, check the ground wire. Rust likes to make the ground loose connection.
SOURCE: 1998 lumina, does not start up with key ignition
Is your security light flashing ?if so you have a problem with the anti theft system.Leave the key on for 10 minutes ,then try this should reset the anti theft system
SOURCE: i have a 96 cavalier.it wouldnt start by using the
it can be the ignition switch or the neutral safety switch. put the transmission in neutral to see if it will start, if it does then the neutral safety switch is bad. if not then check your ignition switch
SOURCE: 2008 impala won't start or shift out of park, key is difficult to remove from ignition.
Sound like a problem with the Neutral Ssafety Switch, this is located on top transmission (generally) and its possible that need some adjust.
