I have owned a Pioneer HTP-2920 Home Theater System for a few months now, and it's worked fine until a day ago. For some reason, I can't get the receiver to make the volume go any higher than -7 dB (it usually goes up to 0 dB). Twisting the knob or lowering the volume on the remote both do not make the volume go beyond -7. I tried unplugging the unit and making sure wires were not crossed, and I've shuffled around between various settings, but nothing has done the trick. Am I overlooking something obvious?
Actually, -7 db and above woul be quite load.
Anyway, I am not very familar with the Pioneer GUI auto setup. But, am aware of how AVR are set-up.
If you have set up the home theatre by auto/manual setup then please check the channel levels whether any of your channels settings is at +7.0db.
If so, reduce this setting where it more +7.0, then you would be able to raise the overall main setting from the volume control to go higher than -7db.( by as much as you've lowered the particular channel setting)
Please do let me know if this helps.
