Belkin (F5D7230-4) Router (587009) Logo
Posted on Apr 29, 2009
Pin number Where is the pin number on this product
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3766
Points
9
Pin number is never put on the unit. if u need a pin number its in the users manual/set up manual if u never changed the origanl pin upon setup. on the back of the router there should be a reset button pn sized of course which will set it back to manufacturers settings which will then take the origanl manufacturers pin number which is in the setup manual
bobby. brady
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 18, 2016
bobby. brady
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3473
Points
3answers
What is wps pin
Wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices.
WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either a button on the product or a an option on the wizard or utility screen.
I have forgotten my PIN number to block my calls what can I do
There is no such thing as a PIN number.
There is a PIN (Personal Identification Number), but no Personal Identification Number Number.
As for the PIN to your phone, you should contact your provider.
I need a wiring diagram for a GM5664
Gateway Support > Gateway GM5664 Desktop PC > Downloads and Support Documents,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2734
Click on the Support Documents tab
(Drivers, BIOS, Applications, Patches, Support Documents, etc)
Click on the blue - 1015004R - Support Documents
Click on Product Views in the list.
Click on Inside View
Go back to the main page
Click on Components
Go to the heading - Motherboards
4006254R - ECS MCP61PM-GM
(AM2 processor socket, MicroATX form factor motherboard)
Gateway Support is of no further help to us. Product Views for the motherboard does not work.
ECS motherboards use a 10-pin Front Panel header, if memory serves.
One pin is not used. (Not there. Number 10 pin)
http://www.ebay.com/itm/GATEWAY-GM5664-MCP61PM-GM-MOTHERBOARD-4GB-Ram-AMD-Athlon-II-Dual-Core-3-0GHz-/360423046239?pt=Motherboards&hash=item53eae33c5f
On the above link scroll the page down, until you come to the enlarged photo of the motherboard, with - Click an Image to Enlarge - under it.
Click on the photo view all the way to the right, on the top photos.
The view shows the 4 orange SATA headers on the motherboard.
(The whitish 24-pin ATX main power cable connector, is shown at the front, with the blue IDE 40-pin header behind it)
To the left of the orange SATA headers (4) is the Front Panel header.
Black rectangular connector with 2 rows of pins.
One row has 4 pins, the other row has 5 pins.
[ The plastic front of your computer is the Front Panel.
The area of pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header ]
Finding where number 1 pin is, is the problem.
Next to the number 1 pin, and silk-screened on the motherboard, is the number 1.
Looking at the rectangular connector (Front Panel header) you will note one pin is missing. This is where number 10 pin would be.
On the opposite side, and opposite end, is number 1 pin.
The pins are numbered Odd, 1, 3, 5, 7, and 9, on the same side.
(Or row)
The pins are numbered Even, 2, 4, 6, and 8, on the other side.
(Or row)
A) Pins 1 and 3 are for the HarDDrive activity LED light.
(HDD LED light)
Pin 1 is for the Positive ( + ) wire.
If the Harddrive activity LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is Not Connected. N/C. Reserved for the factory
D) Pins 2 and 4 are for the Power On LED light
Pin 2 is for the Positive ( + ) wire.
If the Power On LED light is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch. (Located inside the plastic Power On button assembly. It is an ATX power on switch)
http://www.fixya.com/support/t614458-hp_mcp61pm_hm_motherboard_diagram
As for the orange SATA headers on the motherboard. The SATA harddrive should plug into the lowest number of SATA header.
It may be labled SATA 0, or SATA 1.
The beauty of SATA however, is that you can plug the harddrive into anyone of those SATA headers. BIOS will find the device. (Harddrive)
If you need guidance in connecting any other cables, such as power cables, or optical drives, etc, post back in a Comment.
Regards,
joecoolvette
I have a gps and i need an unlock pin cause i bought it and fogot my pin number
Question: How do I unlock my device if I have forgotten the PIN number?
--> Answer: If you have a Garmin Lock on your nuvi, zumo or StreetPilot c500 series and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device.
If you have forgotten your PIN and Security Location please contact Product Support for assistance. Please note we will require a copy of the receipt and there will be a charge to unlock the device as this issue is not covered by the warranty.
To contact Product Support in your area go to http://www.garmin.com/garmin/cms/site/us/support/supportcontact
1helpful
We need instructions for a contour 100 payphone, it is asking for a pin number and we dont have one as we bought this 2nd hand
Welcome to FixYa
Dear User,
Here is the Instruction Manual for you{it may take few minutes to load depends on Connection speed} Click here and Save it..Read carefully to get all details of your product...
It is necessary to Know Old Pin to Change your PIN.Contact the Person who sold the Product to you...He can give PIN Number...And Make Change it...
.If you for got PIN contact Helpdesk
  • Changing your PIn:Page 34
  • Contact Help Desk Details on Page 2 Right side
Hope you got an idea... If this Helps-DONT FORGET to RATE ME......Thanks for Contacting FixYa....
How do I reset pin number as my husbands son must have messed with it before he put in a pin number . I cannot find any reset button.
Where do I find my PIN number ???????
PIN number stands for Personal Identification Number
Most Credit Cards have PIN number.
If you are being asked for a PIN number by a program running on your computer
you can consider that program to be dubious or hacked.
Most software vendors employ a PRODUCT KEY , not a PIN number
PIN numbers are for financial transactions.
If you are being asked your PIN number by a program other than your BANK
or a site that you are purchasing software from , then you are most likely being
tricked by an evil hacker and should not proceed to give them any PIN number.
If this is your credit card or bank card or debet card you are talking about.
Your pin number will be located on the back of the card , the last 3 digits.
Thank you for using FixYa!
Az.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
