If you have a universal remote control, you can set it up to be compatible with your Supersonic TV or JEBSON 3003ES device. Follow the instructions included with your universal remote to program it for use with your particular television or device
Hello
Four digit universal remote code for Supersonic TV/DVD combo is:
0944
Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Codes are bound to the remote, not your set so the model of remote is required and none of the so-called 'universal' remotes really are.
I wish someone would bring a suit against any of
these manufacturers using the term 'universal.' At best, they are 'multibrand' and, with the
proliferation of 'brands,' there never will be one that can rightfully claim to
be 'universal.' There may never be a code for your brand
available in every remote.
What type universal remote do you have? Try searching online for the manufactures site they should have information on the sequence to program as well as the various code for any given brand of TV. Often the model number is located in the battery compartment on universal remotes if it's not printed on the exterior.
